![]() | Home > Puma (Tdci) > 110 Double Cab V Estate |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
I am looking for as many views as possible on the difference in driving
experience between a double cab and an estate. Does the reduced weight in construction on the back make any difference to the ride quality. Is there more bounce? Am I correct that there is less space in the back of a DC and the seat back is more upright. Thanks C. |
cradgebank Member Since: 30 Dec 2008 Location: Nottingham Posts: 308 ![]() ![]() ![]() |
As per TC, ride difference is non existant.
DC is great for carrying dirty, smelly things. Estate / SW models more cargo space and more versatile in what you can carry. 110 DC has smallest load space of any Defender. Richard Either a 90, 110 or 130. Discovery 5 |
The "7 seat" configuration in a 110 SW takes up alot of load space, even when folded away. However the forward facing seats are excellent and comfortable, but take a couple of hours to remove if necessary.
Glynparry25 Member Since: 16 Feb 2009 Location: Miserable Midlands Posts: 3015 ![]() ![]() ![]() |
What about a Utility?...... you keep a spacious second row (Can tilt the sets back further) and you still have a 'dirty' area in the back (Which is secure).
Glyn ![]() |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
I agree with Glyn on this one. I love my DC like I do my left leg but I do hanker after a utility SW. Best of both worlds... If you don't need 7 seats a USW is the way to go.....then when you are just about to part with the cash, veer off and by a DC! Steve |
I would prefer a estate as I already have an svx - not the most practical ! even with 2 back seats.
but the tax and price difference in Ireland between the 2 is huge, there is € 22000.00 difference between a double cab county with abs,air con,cold climate and the same spec estate not to mention car tax of € 240 as opposed to € 2200 a year. DC is vat claimable. the powers that be have not made a ruling on the USW yet. so it is all down to the ride quality C. |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Is it possible to buy a 110 Utility with the two fold up seats in the rear, or do LR only supply them to the Station Waggons? Can the two seats be fitted to a utility if required?
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
Not sure of the tub design in the Utility but I imagine it would be possible to fit the forward facing seats from Exmoor trim even if you can't get the original ones Andy
Nidge Member Since: 27 Jan 2008 Location: Kildare Ireland Posts: 822 ![]() ![]() ![]() |
CR the most cost effective Defender to buy in Ireland, with rear seats is the 130. A big old bus but qualifies for the low VRT rate and vat refundable.
Be carefull of buying a new 110 double cab... as its a grey area and I don't think they qualify for the low VRT rate anymore - some thing along the lines of the length of the load bed in relation to the wheelbase length etc. If I was you I would look for low mileage 110 stationwagon.- pre July 2008 (Still on the lower road tax .) There is a nice xs 2008 model in cork on carzone at the moment. Regards N. |
The vrt rules are changing for 2011 according to Land Rover Ireland and the 110 DC will qualify
as a cat b commercial at 13.5% vrt, they are going to supply them with the canopy on the back which gets the load capacity up to what it needs to be .You are correct at present they do not comply. |
Hmmmmm... Interesting .. ![]() |
around 38k incl vat, DC county with abs/tc cold climate, air con before discount
