No DPF Regen after 2 Years
Having sailed through 2 years of Defender ownership (with just 2 visits to the dealer for standard services) I was musing over the fact that I've never seen the DPF light come on or been aware of the Defender going through the regen process. Should I be worried? Should I ask the dealer to check that the parts are functioning (under warranty)?
The Defender rarely does a very short journey - usually it gets a good run and thoroughly warms up - but now I'm thinking, should I be worried?
23rd Jan 2016 10:21pm
Mjibex
It will have done a regen. It's just not that notable. The light is only to indicate a problem or impending problem.
Mark.
24th Jan 2016 8:38am
Martin Site Admin
The light is a warning light not an operation indicator. RTFM
Being a heavy, square, fuel inefficient vehicle the Defender does a lot of "passive" regeneration so it is not constantly switching active regeneration on. 1988 90 Td5 NAS soft top
2015 D90 XS SW
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
