![]() | Home > Technical > drilling side windows |
NO NO NO it will pop !!!
foxing Member Since: 20 Sep 2008 Location: south wales Posts: 80 ![]() ![]() |
i thought so,any ideas what i can use to glue the glass to the runners?
atb paul |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1822 ![]() ![]() ![]() |
Sikaflex is your friend
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 828 ![]() ![]() ![]() |
Yes, you can drill a hole in the toughened glass. I did it to my first car, an old Lada I had back in the early 90s. Use a masonry bit and take it slowly (obviously not on hammer setting!). I suggest you wear safety goggles because about 10s after I finished the hole, while stood back admiring my handiwork some barsteward that must have been watching me work shot the glass. It exploded into a million fragments and if I had got any of that in my eyes it would have been nasty!
![]() Russian toughened glass must be a bit different then! |
V8_Disco Member Since: 19 Dec 2015 Location: East Yorkshire Posts: 37 ![]() ![]() |
New clips are about £3 ...
the clips are not the problem its getting them to stick to the glass
atb paul |
The bit on the glass? My white plastic clips looked fine but would not hold the edge of the glass new clips fixed it
Swac3 Member Since: 21 Feb 2015 Location: Aberdeen Posts: 363 ![]() |
Ignore the below which was based on me having drilled a nice pair of holes in a 12mm glass fishtank,
HOWEVER :drilling toughened/tempered glass requires a dustpan and brush in addition to a drill ![]() If you're going to do it buy a glass drill, one for glass not one made of glass ![]() Don't go mad on the pressure let the drill do the work and keep it lubricated, if you're doing it outside lay the glass flat and trickle water over the cutting area, hose pipe will do, and be extra cautious at the end when you're about to go through in regards to the pressure/angle you have the drill bit. As with most things like this where you wont have a spare easily to hand its more stressful than difficult. A simple hole like this has to be easier than a 40mm hole cutter :-/ EDIT : havent used those bits that look like an arrow marketed as tile and glass, only the type that are more of a burr and diamond coated. Gary 3 Landrovers Last edited by Swac3 on 22nd Jan 2016 10:58pm. Edited 2 times in total |
Araldite works well, the two part stuff. Ray
Swac3, I was only joking. You can't drill toughened glass, as I found out all those years ago. The amazing thing is I actually achieved my aim, if only momentarily. I can still remember it now, it was a hot day, I finished the hole, stood back and took a swig from a glass of coke and then, BANG! The glass exploded.
+1 this.. glue is prolly more than sufficient despite my previous drilling post
![]() would have been a bit difficult to glue a 40mm hole into the 12mm glass that I did, but for your windows... glue. 3 Landrovers |
just tried this and only lasted for about a week,will get new clips and take to an outo glass outlett and see if they can sort it out atb paul |
I stuck some clips onto my new Windows 6ish months ago and mines still fine. Was the area completely clean and slightly scuffed? Ray
