![]() | Home > Defender Celebration Series & Classic Works > Heritage Defender Extras |
hw7905 Member Since: 05 Oct 2015 Location: Kowloon Posts: 70 ![]() ![]() |
Grab handles look okay on Heritage?? Indeed the original Huey has them also.
flydive Member Since: 27 Aug 2015 Location: Lugano Posts: 290 ![]() ![]() ![]() |
Yes, I like them.
Is one of my planned mods |
steve E Member Since: 06 Mar 2011 Location: Tenby Posts: 2073 ![]() ![]() |
I like them tooo
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2025 ![]() ![]() |
I used to have them on my Series 3 but never figured out what to use them as or for.... 2016 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
I guess they are to protect the rear lamps, or work as buffer before something hits the rear bumper when the spare wheel is removed... Correct me if I am wrong pls.
Just wonder if the steel diesel badge will look nice on a Heritage:
http://www.ebay.com/itm/281891367564 I think the current yellow sticker looks a bit too modern. It will be great if the steel badge can be put on without drilling any holes, say using Pritr sticky tac?? |
Avion8 Member Since: 26 Jan 2015 Location: Perth Posts: 281 ![]() ![]() ![]() |
Thanks to YOLO I now have some nice FCX dashboard trim fittings.
[URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] [URL=] ![]() Click image to enlarge[/URL] The hardest part was swapping the opening lid on my glovebox. Not quite Grasmere green, but setting a green theme.. :mrgreen: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
YOLO110 Member Since: 14 Feb 2015 Location: Perth Oz and Stansted UK Posts: 1646 ![]() ![]() |
Blimey Nigel! That was quick!!!
![]() I have just got back! Needed to cool off in the 35C heat today I think they look pretty cool actually... a much closer match than to Keswick! There is definitely an increasingly active 'Green Brigade' happening on here now... with 'Uncle Rog' leading the way! Nice to meet up and to see all your other 'toys'... now get that lovely wheel fitted as well! ![]() Cheers, Pete. ![]() |
Thanks Pete,
I'm getting good at prizing those spring clips off the glove box lid. I'm very happy with the green, & don't think it has to be an exact match, just a nice contrast. Just need to find a spot in the shed now to store all the original removed hardware, where I can find it again! I will work on the wheel one cool day, the last steering wheel I removed took 3 days off the old 80". Maybe the fact that it had been there 60+ years had something to do with it's stubbornness? Cheers, Nigel |
I found my Defender wheel came of with hardly any effort!
Loosen, but don't remove the nut (that was not even 'tab locked' in position), then a few wiggles and a firm pull had it easily off the splines against the nut. Make sure the previous wheel was dead straight, then just a matter of removing the nut and swapping the wheels over! Took me about 10 minutes. This was compared with my Lotus that needed a wheel 'puller' despite having a big spring under the splines. If you removed the nut off them before removing the wheel, it was destined to end up in your chest at high speed! Glad you like the trims mate! I think a matching green 'Huey' box is in order to keep all the stuff in! ![]() |
integrale Member Since: 29 Oct 2015 Location: Auckland Posts: 77 ![]() ![]() |
Rear grab handles arrived today. Went to fit them......and there's a large (silver painted) bolt in the way stopping them fitting either side. Defender 90 Heritage. |
TonyF Member Since: 13 Aug 2015 Location: Tasmania Posts: 61 ![]() ![]() ![]() |
yes, with rear seats and strengthening for seat belts I don't think it's possible without some modification.
There was a post about this issue before:
http://www.defender2.net/forum/topic37340....ab+handles |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
That's a "posh" copy of the original LR part: ![]() Part number 502951 - about £3 from a LR dealer in the UK before discount You could indeed use double-sided trim tape to fit it ![]() ![]() ![]() |
