Home > My Defender > My new (to me) Defender 90 Puma
Page 26 of 34 <123 ... 252627 ... 323334>
BossHog
Have you fitted the Dirt D Fenders on the front and back or just the fronts ?
Post #493746 18th Jan 2016 5:26pm
RRUK
Just the fronts. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #493918 18th Jan 2016 10:23pm
Mickysham
Ireland 2004 Defender 90 Td5 CSW Barolo Black
I love this post! Read every page and so much inspiration for my own..
Post #493927 18th Jan 2016 11:03pm
BossHog
Since I have fitted the spacers I'm getting a bit of spray up the door, and I like to drive with the window open Confused so I think I will fit some on the front also now that they seem to help
Post #494058 19th Jan 2016 1:38pm
RRUK
A quick internet purchase.
I emailed MUD before xmas about their sun visor mirror to see if they did it in black too, so it matched my nice black headlining and sun visors, and now they do!
So, ordered one for the passenger side and a couple of their curry hooks to put in the rear to hang coats on when out shooting. 2016 D4 HSE
Post #494480 20th Jan 2016 5:48pm
Sadi
Namibia 2016 Defender 110 Puma 2.2 Heritage Edition SW Grasmere Green
RRUK wrote:
Just the fronts.
Hi RRUK,
The Dirt D-fenders come with a short piece of foam with an adhesive backing.
What exactly is this for please - if you used it during your installation ?
Thank you.
Post #494504 20th Jan 2016 7:06pm
RRUK
The single foam strip is so that you can plug any gaps due to land rover build tolerance. I found I used a bit in each corner. 2016 D4 HSE
Post #494516 20th Jan 2016 7:47pm
Sadi
Thank you !!!
Post #494620 21st Jan 2016 4:15am
RRUK
More presents in the post.
The MUD sun visor mirror arrived, along with the 2 curry hooks which I shall use as coat hooks.
The mirror looks better than on the MUD site as the grained finish looks better than their photos, and the entire back is covered in a sticky pad. These are designed for the original sun visors, I'm not sure if they would work on the black alcantara ones (do they have mirrors in them already?)
The curry hooks just need two small holes drilled into the plastic trim to fix, the lower is a positioning peg and the upper for a self tapper.
Easiest jobs ever.
 2016 D4 HSE
Post #495173 22nd Jan 2016 2:05pm
RRUK
Was in Tesco today in the motoring section and saw this little gizmo.
Basically it must be a bag of Silica Gel crystals or similar.
A coloured indicator on the outside shows you when it is saturated and you recharge it by heating on a radiator or in the microwave.
For a car like a Defender which can easily get damp inside with drips and leaks, this seemed a no brainer to me so I have installed one in the cab. It was £7.50.
Pic to follow. 2016 D4 HSE
Post #495218 22nd Jan 2016 4:24pm
RRUK
 2016 D4 HSE
Post #495220 22nd Jan 2016 4:27pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Those Mudstuff mirrors do work with the black headlining visors Thumbs Up
These new ones look rather better made than previous versions from Mudstuff, which appeared to be held together with hot glue and I had one come apart. The new ones appear to have a proper retainer for the mirror inside the plastic frame - very nicely made. Dave
Green Goddess - 1998 Defender 110 300tdi
Post #495229 22nd Jan 2016 5:00pm
Ryderoo
England 2015 Defender 90 Puma 2.2 HT Santorini Black
RRUK wrote:
Looks good, I would be interested to hear how you get on with this product RRUK.
Also I'm thinking of getting the Mud vanity mirror for the Missus for Valentines day Wink she always checks for a mirror when she jumps in the Defender. Cheers Simon
I can explain it to you, but I can't understand it for you
1990 110 TD5 county, my first Land Rover - gone
2012 Discovery 4 XS SDV6 - gone
2014 Discovery 4 XS SDV6 - gone
2015 Evoque SD4 dynamic - Wife’s - gone
2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone
2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24
2021 Defender S D250 Santorini Black 110 HT - gone March 24
2023 Evoque P300e SE wife’s current vehicle
Post #495258 22nd Jan 2016 6:36pm
RRUK
A couple of tweaks.
Fitted the MUD hooks in the back on each side for hanging my shooting coat. Simple to fit. The positioning peg on it needs a 4mm hole to seat it, then I used a 2.5mm drill for the pilot hole and the s/s self tapper screw in each. I positioned them near the metal hanging support bracket for the side trim for extra strength.
Next I measured and cut a piece of the windscreen sun film to help with the blinding sun rays that get between the rear view mirror and the sun visors when it's low in the sky.
Fitting is simple, pull the film apart to reveal the tinted side and coat in soapy liquid from a spray gun, plus on the glass. Then slip on to its position and spray the top surface. This lubes the squeegee as you work out the liquid and air bubbles till it's flat and sealed. Then dry and leave taking care not to move it. Be gentle.
It may not look very fancy but it's functional and it works. If you look at the pics you can also see the MUD vanity mirror in place.
 2016 D4 HSE
Post #495823 24th Jan 2016 2:50pm
Butchers Boy
United Kingdom 2010 Defender 90 Puma 2.4 HT Stornoway Grey
Looking really nice Adam Thumbs Up 2010 Defender 90 HT
The longer I live..... The better I was!
Post #495846 24th Jan 2016 4:49pm
