Home > Td5 > Slickshift
Page 1 of 4 1234>
grafty99
Slickshift
Evening all.
Just received my slickshift in the post today - it looks quite nicely made. Can't fit it yet as my defender is away but I'm looking forward to it!
I haven't really heard anything negative about fitting one but any tips, tricks or experiences whilst fitting or in use?
Many thanks! Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #494230 19th Jan 2016 10:15pm
muddybaldboy
Wales 1999 Defender 110 Td5 HT Chawton White
Watching this thread closely, on my wish/to do list Cool He who dies with the most toys...wins!
Post #494231 19th Jan 2016 10:16pm
grafty99
I'll upload pictures and my thoughts when I've done it. A lot of people say it's one of the best things they've done to their defender 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #494232 19th Jan 2016 10:18pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
This is an awesome mod and well worth the money and it is silly simple to install. I put one into my previous LR and took it out to put into my new (to me) 2000 MY 110. Unfortunately the AC plenum and vents impeded the shifting and the newly raised height of the shifter, about one inch, is just enough to cause the shifter to hit it. Sad
As installed on my old SIII Tdi 88 five sped it was just amazing. The short throws are great and there so much less arm flinging. It feels like a car!!! It cuts the shifting movement about in half. Cannot say enough good things about this product. Thumbs Up Loved it but alas had to put it back in my old LR and sold it with it. Big Cry 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #494243 19th Jan 2016 10:35pm
grafty99
That's interesting. I plan to retrofit aircon to my defender at some point so this could prove problematic, although, with tweaking I'm sure I could make it work Thumbs Up
Otherwise its good to hear yet another good review. I'm really excited to fit it, just need my defender back Twisted Evil 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #494252 19th Jan 2016 10:48pm
4RF RDS
Actually I slightly bent the shifter just a bit to give that 1/4 inch clearance when I have to push it into first when its cold (renowned R380 notchiness). 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #494283 20th Jan 2016 1:53am
Johnb
United Kingdom 2004 Defender 90 Td5 CSW Belize Green
Fitting the Slickshift was the best mod I have made to my Td5 Bow down
The air con doesn't get in the way.
Just remember to clean all the old grease out of the turret and re grease with new, take your time with setting up the bias springs.
Enjoy Thumbs Up
Post #494356 20th Jan 2016 10:49am
jeffersj
United Kingdom 1996 Defender 90 300 Tdi HT Bronze Green
Did the same to the Tdi and now only minimal movement between gears.
There is a good "how to" video I think on Paddocks site if you bought it from them or even just a general search under "how to" will get you an informative video. I did it so anyone can! Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #494377 20th Jan 2016 11:59am
excossack
Does this help remove any drive line clunking between gear changes? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #494399 20th Jan 2016 12:51pm
jeffersj
Shouldn't think so, it just reduces the travel of the long gearstick. That sounds like wear in the drive train. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #494435 20th Jan 2016 2:04pm
LandieG
just done my first week with slick shift, what a difference!
more dependent on good set-up of bias springs, and won't help a poor shift, but it really makes changes neater and as per the description, slicker!
Post #494441 20th Jan 2016 2:28pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Agreed with all the above, I fitted one to mine a couple of weeks ago and it's definitely nicer to drive, so much so that my daughter immediately got me to order one for hers.
It fits in my Td5 with the AC with no clearance problems at all Thumbs Up
The only issue I found was that when pulling the old gearstick out of the housing, the spring in the back of the "ball" part went ping and shot off to the darkest receses of nowhere, when I eventually found it, there was obviously a bit missing to prevent the outer end of the spring from wearing against the housing, it took a little while longer to discover the little nylon "mushroom" that goes in there. Doing the same job a second time I knew what to expect Whistle
Post #494467 20th Jan 2016 4:50pm
jeffersj
As Clive said be careful of this part spring out, the videos highlight this point. Jeff
Ex 1968 Series 2A
Ex 90 TD5
Ex D3
Ex D4
Post #494815 21st Jan 2016 2:43pm
marksolesbury
I have one too - its awesome. I bought it at Billing and fitted it on our stand.
Post #494836 21st Jan 2016 3:46pm
marksolesbury
.h 1996 300tdi 90
Northants4x4.com admin.
Post #494837 21st Jan 2016 3:47pm
Page 1 of 4 1234>
