Home > Puma (Tdci) > Puma 90 rear mud flap bracket replacement
Rogeo1983
2010 Defender 90 Puma 2.4 CSW Zambezi Silver
Hi everyone,
I'm a bit stuck, looking for some help.
The rear mud flap brackets of my 59 plate defender are rusting quite a bit, and I purchased a new set.
I set about replacing them, but now I am stuck.
The bolts while moving, suddenly started turning freely as if the nut on the back is loose.
So I am puzzled for the following.
Are the nuts on the back captive nuts?
Any idea how to gain access to them?
The other alternative is to rivet the new brackets, however I think the holes are about 8mm, and I cannot find a rivet larger than 5mm.
Is there a simple way to replace these brackets?
Many thanks
Post #493936 19th Jan 2016 12:13am
rustyboxx
United Kingdom 2015 Defender 90 Puma 2.2 CSW Montalcino Red
IIRC it's rivnuts in the crossmember and they can be a right pain.
Sometimes using a bit of downward pressure, using a lever between the mudflat bracket and crossmember, to give the rivnut more purchase can allow the bolt to be unscrewed. I would spray some penetrating oil around first. Failing that its cutting the bolts off, drill or knock out the rivnuts and replace with new ones plus bolts. 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching
2005 90 Td5 XS CSW - Utterly brilliant
2001 Discovery 2 ES Auto - A phase I went through
1996 90 Tdi CSW - Uber reliable
1989 90 2.5 Petrol Hardtop - My first proper Landy
1985 Range Rover Vogue V8 -Troublesome
Post #493938 19th Jan 2016 12:23am
Rogeo1983
Hi many thanks for your reply.
The problem I have is I cannot get access to the nut. The crossmember is boxed in. At the moment even if I get the bolts undone, I will not be able to hold the rivnut to add new bolts, or nuts and bolts for that matter.
All I can think of is using a small magnet to hold a washer behind the hole and use a river to reattach, but that's near impossible.
How did they get them in there in the first place??
Many thanks
Post #493940 19th Jan 2016 12:52am
If you manage to get the existing bolts out of the rivnuts, leaving the rivnuts intact, you can then use a simple homemade tool (look on google) to tighten the rivnuts to stop them spinning again
Post #493950 19th Jan 2016 7:27am
Rogeo1983
The existing bolts are rusted beyond use, I'm going to have to cut them out.
I have just ordered a rivnut tool with some stainless rivnuts, they should work fine.
Many thanks
Post #493954 19th Jan 2016 7:52am
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
I had the same problem, the funny thing was that the bolts I used the penetration oil on we're the ones I had trouble with spinning rivnuts. End result was only two rivnuts now remain. I cut the bolts out using a new hacksaw blade pushed inbetween the bracket and the underside of the crossmember. Fished out the rivnuts complete with bolt shanks using a magnet. Painted the underside of the crossmember, job done, doubt the mud flaps will be replaced, underside doesn't hoard as much muck now and no nasty trap between brackets and crossmember.
Post #494539 20th Jan 2016 8:31pm
Crofter
United Kingdom 2009 Defender 110 Puma 2.4 USW Baltic Blue
I found a rear nearside mud flap hanging of today. It looks like the failure was a broken bracket at the outside bodywork end. The other end was still connected and as you say it the bolt was corroded. I pulled the bracket off it looks like I may be able to get a small spanner (8 or 10mm in to the box section through the opening near the bracket mounting).
Hope to get a better look tomorrow.
Post #495570 23rd Jan 2016 6:10pm
Rogeo1983
Ok quick update,
I purchased on eBay a rivnut tool with 100 pieces of various sizes of rivnuts. The total cost was less than £20.
On Monday I will be cutting and drilling out the old to put in new nuts, and attach the new brackets with stainless bolts.
I will post pictures...if I can figure out how to do it!!
Is there a page for members showing with pics how to do jobs? Would be worthwhile having.
Back soon
Post #498296 30th Jan 2016 5:35pm
