Home > Puma (Tdci) > Engine swap |
Pilgrimmick Member Since: 16 Nov 2015 Location: Highlands Posts: 582 |
What engine box is coming out and what going in?
2nd Jan 2016 7:49pm |
Cold_n_Wet Member Since: 15 Oct 2012 Location: Bergen Posts: 244 |
2,4 TDCI out same out, 07 out 2010 in.
Glen "Rafiki" 2007 110 STW - Rolling rebuild. |
2nd Jan 2016 7:56pm |
212 views and nobody has experience of changing eingines , must be fairly straight forward. "Rafiki" 2007 110 STW - Rolling rebuild.
7th Jan 2016 4:33pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Drop the box, that's straight forward even better if you have it on a lift, and have a gearbox jack.
Remove the rad, intercooler, air con if fitted, so the engine can come out forwards. You could probably leave it in place but it'll give you more space to work, and make it easier in the long run. Start by removing the air box pipe work, etc. The Puma loom is fairly straightforward to remove, these need to go back in Exactly the same place as it was routed. Otherwise you will get rub throughs latter in service. Take clear photos if you like, of how the cables sit, and are placed through, and around ancillarys. Go in with a clear head, use logic and you will be fine. All the plugs on the loom will only fit the correct connector, so don't worry too much if you loose your way a bit! Once you have removed remaining pipe work, fuel and water, engine mounts etc, simply crane it out through the front. Cover all fuel pipes on the engine, and the engine bay with latex gloves or similar, Keep it clean as much as you can. Then simply start all over again in reverse. Swap injectors, or re code, get some small injector O rings,for the leak off pipes, the green ones as sometimes these can split on re fitting. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
7th Jan 2016 6:30pm |
Take lots of photos, wiring, hoses, etc. Then when you have a problem you have the definitive answer 80" 1948
Lightweight V8 Bowler Tomcat 130 Station wagon 90 300tdi (Santana PS10 pick up) Range Rover L322 (Ful fat) |
18th Jan 2016 1:08pm |
