Home > Maintenance & Modifications > Anyone installed a Safety Devices 'Style Bar?'
Page 2 of 2 <12
Alex1976
No I don't see any difference in visibility as the bars sit in line with the windscreen pillars so you don't actually see the cage from inside really.
Post #493121 16th Jan 2016 10:44pm
boode
England 2003 Defender 90 Td5 HT Rutland Red
This is my Defender
The Bars are actually a full roll cage with an internal hoop - from Safety Devises - as fitted to the 50th special
The internal hoop is not braced so does not impede internal space or access to the back - but still gives protection in an accident
Also no limit to visibility
view of internal hoop
Post #493123 16th Jan 2016 10:57pm
Alex1976
Pics of my style bar this morning (including the first snow of the year!)
Post #493192 17th Jan 2016 9:59am
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
Perfect, thanks for that Alex, much appreciated.
Paul
Post #493196 17th Jan 2016 10:11am
Alex1976 wrote:
I feel that apart from the cosmetic benefits it also adds some rigidity to the body. Well it feels as if it does.
Before I read your comment, I was actually thinking the opposite - in the sense that it would transfer bending/twisting forces across two surfaces subject to different twisting forces. Are there load spreading plates on the internal surfaces?
Post #493232 17th Jan 2016 11:52am
SD do a version with braces that don't appear to impede rear space at all:
Whilst it may give a degree of protection in certain roll over situations, I think without the rear bracing then it's too compromised to really be called a roll cage.
Post #493235 17th Jan 2016 12:01pm
boode
I would agree that I have purchased a compromise roll cage
It will not give as much protection as a full external cage - which I could not fit due to the extra fuel tank position
The internal hoop without bracing (it still has a hoop under the floor and the one seen that replaces the bulkhead) allows the seat to go further back - which was important to me
It will as you say give a degree of protection - it will not protect the vehicle from being damaged - but hopefully it will give sufficient protection for the passengers to survive a roll
This 50th rolled (both front wings were squashed) but the cab remained intact - costs about £500 more than a style bar
Post #493353 17th Jan 2016 5:52pm
deep down
Wales 2007 Defender 110 Puma 2.4 DCPU Zambezi Silver
I have an SD one I removed to fit a full roll cage.
No internal hoop, needs a bit of cosmetic touch up, you can have for £190.
Only thing is it's in France.
I'm away at the moment but will try and get some photos of it if you're interested.
Post #493365 17th Jan 2016 6:30pm
Lambley
Thanks for the replies and pictures etc, deep down - thanks for the offer but I'll probably give SD a call in the morning and get some advice and specs for a new one, chances are I'll go for a L230 style bar in black if they do one, or a L138/7 like boode's above, but thanks all the same.
boode - I contacted D44 about a bumper like yours in the pic above but never got an answer or a call back, ended up doing my own in the end.
Post #493482 17th Jan 2016 9:37pm
Page 2 of 2 <12
