Home > Maintenance & Modifications > Anyone installed a Safety Devices 'Style Bar?' |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Without internal hoop it would only be cosmetic!
16th Jan 2016 11:55am |
camelman Member Since: 27 Feb 2013 Location: Peak District Posts: 3372 |
As ibexman says, the external hoop mounted to the body would be for looks only as there is no structural benefit.
On my last hard top I went for the SD cab protection cage which has the internal hoop behind the driver and then external over the front roof and screen. Click image to enlarge Click image to enlarge |
16th Jan 2016 12:15pm |
Lambley Member Since: 20 Apr 2013 Location: Mid Devon Posts: 1435 |
Cosmetic only is fine, I'm not after more protection just looks cool to me
16th Jan 2016 3:24pm |
chrispy Member Since: 13 Mar 2015 Location: Gwent Posts: 347 |
I considered putting one on my wifes 90 but she wants a Massai style roof rack and it won't fit with one of those.
16th Jan 2016 3:37pm |
Sailingtom had one on his td5, you might drop him a PM ?
16th Jan 2016 3:51pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
Do they do a set up like this for the 5 door csw? My 109 thread my youtube channel |
16th Jan 2016 4:36pm |
i will do, thank you. |
16th Jan 2016 5:16pm |
CarMan Member Since: 29 Nov 2010 Location: Cotswolds Posts: 1861 |
I like the look at that - do you have a price? Rob
1993 200tdi 90 hard-top 1998 300tdi 90 soft-top 2016 2.2 XS 90 hard-top (sold) |
16th Jan 2016 5:33pm |
Yep, have a look at www.safetydevices.co.uk and go to the expedition tab.
16th Jan 2016 5:53pm |
Looks like there's 2 in the range - one looks like it's thicker and in silver only (RBL2303SSS) at £588, the other is black and is a bit cheaper (RBL1383SSS) at £545 (from Paddocks)
I guess I'll have to make some enquiries on Monday, the silver one looks better and thicker but I would have to get it powder coated black which I'd guess at an extra £50? [URL=] [/URL] [URL=][/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
16th Jan 2016 5:57pm |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 |
I have the style bar on my 90. I bought it second hand and it came off a G4 style defender, so it was a genuine LR product, although I believe they are made by Safety Devices for LR.
It was easy to fit, I decided to fit it using large rivnuts so I could bolt it in without having to get to the inside of the wings/roof with a nut and spanner. I used stainless steel socket head bolts to mount it and coated them in Dynax wax first to help prevent bimetallic corrosion and also seal the bolts to stop water ingress. I feel that apart from the cosmetic benefits it also adds some rigidity to the body. Well it feels as if it does. |
16th Jan 2016 7:53pm |
Cheers Alex, sounds good advice to me, any pictures?
16th Jan 2016 7:59pm |
I can take a couple in the morning and post them on here for you.
16th Jan 2016 8:23pm |
That would be great, thanks. One question - does it limit visibility around the screen at all?
16th Jan 2016 8:43pm |
