Home > Maintenance & Modifications > Help With SVX Light Sizes
chrispy
Wales 1987 Defender 90 300 Tdi CSW Keswick Green
I've bought an SVX after-market grille for my wifes 90 but i'm having trouble finding the lights to fit into the spotlight/sidelight hole. Can anyone help me with a link to or dimensions of the side/spot lights please? I have the indicators sorted with led ones but the others are baffling me. Bolt on Bits do a kit but i'm reluctant to shell out £250 for the whole kit when all I need is those two.
Thanks in advance Thumbs Up
Post #492897 16th Jan 2016 11:11am
ericvv
Post #492901 16th Jan 2016 11:21am
chrispy
Thumbs Up
Post #492904 16th Jan 2016 11:28am
ericvv
In the SVX these 90mm halogen driving light are factory installed with a relay. Make sure you do the same as if you would connect these direct to the light switch in addition to the main headlights, you would have a fast total meltdown of the switch I think. Laughing
Better, use the opportunity to also install the Swedish light enhancer loom for the main headlamps, the very good one from Landreiziger for instance. Thumbs Up
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #492924 16th Jan 2016 12:49pm
chrispy
So it's probably best I actually order the full light kit and loom from Bolt on Bits then?
Post #492926 16th Jan 2016 12:50pm
