Home > Puma (Tdci) > Swapping Glow Plugs
Caterham
Swapping Glow Plugs
Not got round to testing them yet (a job for the weekend) but I got wondering and did a search but couldn't find anything.
anyone here replaced their glow plugs on a Puma?
I understand they can be a pig to get out?
- also once the engine is up and running how much effect do they have on the running of the engine (if any)?
Post #492590 15th Jan 2016 1:19pm
ARC99
United Kingdom 2008 Defender 110 Puma 2.4 USW Cairns Blue
As far as I'm aware, then again I might be wrong, once the engine has started the glow plugs do nothing at all as they are only used to aid the starting. Don't make old people mad.
We don't like being old in the first place,
so it doesn't take much to Censored us off.
Richard
Post #492662 15th Jan 2016 4:23pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
All glow plugs do is preheat the air in the combustion chamber prior to starting, once the light goes out on the dash they have stopped working. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #492665 15th Jan 2016 4:26pm
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
Good lord, what's wrong with it now?
Post #492678 15th Jan 2016 4:46pm
Caterham
Very Happy smoke and rough on start up. Suspect a dodgy glow plug.
Will test them when it stops raining the w/e.
Post #492727 15th Jan 2016 6:58pm
Retroanaconda
In a lot of cars the plugs are on for a short while after starting to aid combustion while the cylinder is cold. The light going out is the signal to the driver to start the engine, not the indication that the plugs have shut off.
On mine if you turn the ignition on and just wait the light goes out after a few seconds (where you would normally start it) and then a short while later you can hear the click as the plugs are turned off.
Post #492794 15th Jan 2016 10:20pm
Not correct.
They operate for 3 separate tasks:
1. Cold start
2. After glow
3. DPF active regeneration
Post #492804 15th Jan 2016 10:33pm
Caterham
Thank you.
What's after glow? Does this aid combustion during normal running. Ie are the plugs assisting all the time?
Post #492841 16th Jan 2016 6:22am
Cupboard
The plugs aren't going all the time, but they run at a reduced voltage for a bit once the engine has started and is still cold.
Post #492874 16th Jan 2016 9:34am
Glow plug facts from the MY12 Workshop manual :
"The glow plugs are a low voltage metallic type that operate at a maximum tip temperature of 1050 °C (1922 °F),
achievable within 2 seconds."
"The ECM (engine control module) uses the signal from the ECT (engine coolant temperature) sensor to determine the preheat time. The lower the temperature, the longer the preheat time. There is a maximum preheat time of 2.1 seconds at -20 °C (-4 °F) or lower. At temperatures above 20 °C (68 °F) there is no preheat phase."
"Once the engine has started, if the engine temperature is less than 70 °C (158 °F) the glow plug system enters an afterglow phase. The after-glow phase lasts for a maximum of 500 seconds, or until the engine temperature reaches 70 °C (158 °F). The tip temperature of the glow plugs is reduced as the engine warms up. The ECM uses a glow plug control map of engine speed against load to determine the optimum tip temperature during the after-glow phase. At high engine loads the after-glow phase is interrupted to protect the glow plugs and improve their durability."
or a potentially contradictory statement:
"After-glow is designed to function at engine temperatures below 50°C (122°F), below 2,500 rpm and for a maximum of 30 seconds after engine starting."
"During the active regeneration process the following ECM controlled events occur:
The glow plugs are occasionally activated for up to 40 seconds to provide additional heat to assist in raising the DPF temperature."
I believe that the glow plugs active indicator (the amber light in the instrument cluster) only illuminates for the pre-heat function due to the the ignition switch being turned to position II.
Post #492906 16th Jan 2016 11:43am
Caterham
Bow down
Anyone here them over....i hear lot of horror stories?
Post #492916 16th Jan 2016 12:15pm
Mash
How times have changed, and there was me using my 80's diesel tech knowledge, always glad to learn Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #492920 16th Jan 2016 12:36pm
They certainly have - not necessarily for the better.
I was surprised most by the maximum time they operate on cold start - 2.1 seconds. On some previous vehicles I had to do double doses of 10 seconds to get the old girl to fire up smoothly!
Post #492944 16th Jan 2016 2:09pm
Caterham
Shocked
thought I'd just 'pop' out and check the glow plugs, small socket set, multi-meter and 10 minutes should do.
F ' in aida - I think I might need to set a day aside in the summer. I'm guessing the only chance of doing that is inlet manifold off?
with the chance of snapping a glow plug off I'm wondering if installing a webasto type diesel heater might be easier and do away with the need for glow plugs plus all the other benefits.....and if a plug does snap off could prove cheaper overall?
Post #492961 16th Jan 2016 4:09pm
Wouldn't it be easier to just use a scan tool and read any diagnostic trouble codes and see if they are associated with the glow plugs?
Post #493201 17th Jan 2016 10:26am
