![]() | Home > Maintenance & Modifications > AlphaTherm Installation |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
Apologies, finger trouble, first picture should have been:
![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Excellent write up
![]() ![]() Though I have always used 50/50 mix of additive without the nozzles freezing up (even at -20 at the beginning of this year), this would be a cheaper option than using washer additive all the time. Let us know how it performs at removing traffic grime and if you will still add a little additive. Does additive cause any problems with the heating element or internal workings? Also did you fit this to help defrost the windscreen, stop the nozzles freezing when driving or as a viable alternative to screen wash? Sorry for all the questions but have been looking at getting this for my Landy to work along side Entreq's new higher capacity windscreen washer jet (once they release it.) Cheers Brian. |
Brian,
You still need to use screen additive to stop the washer fluid freezing and the manufacturer recommends it so it won't save you any money. I got mine partly out of cuiosity if I'm honest, though it was prompted by Dgardel's post and by a frustrating motorway jouney where the only way I could defrost the washer nozzle was by pouring my daughter's hot tea over it from her flask (mine contained whisky so no use at all! - though to be fair I didn't try). I'm not a fan of scraping the windows in the morning so I figured if it coudl help that and keep the nozzles clear then it was worth a try. |
