Home > Maintenance & Modifications > Removing Puma front door trim cards
YOLO110
Australia
Help please!
I would like to remove and then refit my front door trim cards on my Puma 90 to do some soundproofing and trimming.
Can anyone give me a 'Noddies Guide' with perhaps some pictures how to do this please? It looks like it should be quite a straightforward job but I am guessing clips/fastenings etc may perhaps be a challenge when re-fitting...
Many thanks in advance,
Peter. YOLO... You Only Live Once...
Post #491058 11th Jan 2016 4:21pm
RRUK
I've not done the front doors, but have done the rear door and other vehicles.
It always helps to have a few spare trim clips in house, as some are bound to break or be weakened - that's what I found most annoying, the clips hold tighter from new, once they been removed and replaced once or twice they can lose their spring and form and therefore can be a bit looser, resulting in rattles and squeaks.
These have come in handy a few times but they are not cheap.
http://www.paddockspares.com/assorted-trim...280pc.html
Plus this place is cheaper...
http://vehicleclips.co.uk/ 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #491062 11th Jan 2016 4:27pm
Treebeard
United Kingdom 2005 Defender 110 Td5 CSW Chawton White
Get a decent trim removing tool. Best done on a warm day as less chance of snapping the fittings
Post #491263 11th Jan 2016 10:35pm
Post #491290 11th Jan 2016 11:35pm
LR90XS2011
re removal of the door cards, as stated trim removal tools help, remove grab handle and the screw in the door open handle trim and remove them, then gently pull the bottom of the panel out using the trim tool to ease the clips out, should all go well if you are gentle and steady, did mine with no issues. When you have it off check the screws in your door handles I had 1 fall off which is why I dad to remove my trims. DEFENDER 90 TDCI XS,
Post #491312 12th Jan 2016 6:28am
YOLO110
Australia
Many thanks for the replies guys!
So, bought my trim tools today!
Now, to work! Pics will follow when I get things going!
Cheers, Pete. Very Happy YOLO... You Only Live Once...
Post #491318 12th Jan 2016 6:55am
The trim around the lock peg is best removed with a block of wood under the lower edge hit with a hammer from below.
The two black plastic 'visible' clips have a centre pin that needs to be pushed in - but not too far - so that they can be removed
Aside from the clips across the top under the window, all others can be removed very carefully and gently with your trim tool.
Once everything is released lift the card slowly at an angle outwards from below and this will release the top clips
Post #491325 12th Jan 2016 7:25am
YOLO110
Australia
Thanks very much for that information guys. Thumbs Up YOLO... You Only Live Once...
Post #491334 12th Jan 2016 8:25am
Another thing to watch is the areas where the paint are. Use some tape on the paint to avoid the back of the tool damaging it. Thumbs Up
Post #491375 12th Jan 2016 11:33am
RRUK
or slip something like a thin credit card/ loyalty card behind the tool as you go 2016 D4 HSE
Post #491422 12th Jan 2016 3:14pm
