Home > Maintenance & Modifications > Horrible noise on over-run |
Freypal Member Since: 23 Sep 2013 Location: Shropshire Posts: 271 |
On the way back from work my td5 90 has started making a horrible noise when on the over run. Seems a kind of squealing high pitched noise. Definitely linked with rotation. Only happens on overrun. I suspect front prop UJs but is there anything else to check? I'm assuming a DMF wouldn't make such a noise on the way out?
11th Jan 2016 6:22pm |
From in the car it sounds like it's emanating from the transmission tunnel area. Doesn't sound like a drive belt, it's more metallic. Cheers for the suggestion!
11th Jan 2016 7:42pm |
