Home > In Car Electronics > ..reverse parking switch..
Ecco
Malaysia 2014 Defender 110 Puma 2.2 DCPU Galway Green
..hi guys..where is located switch, turning on reverse beep signal?? Recently, it behave random, sometimes work when i set to reverse, sometimes not..i was wondering, where switch (or whatever activates it when in gear reverse) is located so i can take a look myself, if it is not much work so i can replace myself without LR knowledge or bringing car to them..
Post #491003 11th Jan 2016 2:15pm
The reverse light switch on on the left hand side of the main gearbox, quite high up, towards the rear, and is fairly inaccessible.
Standard Defenders (in the UK, at any rate) don't have reversing beepers, but I imagine that these are connected into the same circuit as the reversing lights.
Do your reversing lights work properly, or are they also malfunctioning? If they are malfunctioning, then the switch could well be the fault. It is not unknown for the switch not to be properly screwed into the gearbox during manufacture - in which case simply tightening it up may solve the problem.
Post #491023 11th Jan 2016 3:03pm
Ecco
..reversing light works fine and so far no issues of any kind with such things..its just beeper which indicates distance, randomly working..sometimes as expected, sometimes not at all..
Post #491030 11th Jan 2016 3:08pm
Perhaps it is the beeper itself then. Try replacing it with a test lamp (or connecting one in parallel with it) somewhere you can see it and see if the test lamp also doesn't work. If the lamp is OK and the beeper isn't, then the beeper's the likely problem.
Post #491031 11th Jan 2016 3:11pm
