![]() | Home > Technical > Stranded, help please. |
chris38 Member Since: 24 Oct 2014 Location: Lancaster Posts: 34 ![]() ![]() |
Drove up to Gatehouse of Fleet a couple of days ago to stay in a cottage. When I came to start the Landy again it wouldn't crank.
Found the rearmost 60amp fuse in the engine bay had blown. Replacement blew straight away. Tried to get recovery who can't seem to find the problem. (Didn't look very hard to be fair) Am trying to get an auto leccy to have a look tomorrow. But otherwise I'm stranded and can't get home. Can't find any obvious bad earths or damaged wires. I did get a whiff of electrical burning just before I stopped the engine. Anyone got any ideas what could be the problem. There's a beer or three in it for you. Many thanks Chris Cheers Chris 300tdi Defender 90 |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
Do you get a click click on start up ie starter relay working but started motor windings shot?
Good luck. |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
is the rearmost 60amp fuse second from bulkhead ? i.e. there is a 30 amp fuse closest then 2 60amp a 20 and a 60??
if so then that 60a fuse is for the ignition switch and starter relay!! possibly relay failure or ignition switch failure My 109 thread my youtube channel |
Nope nothing at all, Cheers Chris 300tdi Defender 90 |
Yep it's that fuse, can you think of any reason why it would blow again straight away. Key wasn't in ignition when it blew. Cheers Chris 300tdi Defender 90 |
Aha. Hopefully gmack above has the answer...shot relay.
Should be an easy fix if that's what it is. Good luck. ![]() Short in the relay? |
also check for any chafed wires around bell housing as i think they can rub there! My 109 thread
Thanks for your replies guys.
So if the relay has gone would that fit the symptoms Slight burning smell before switch off. Ignition lights switch on with key but on final turn nothing happens. Fuse blows immediately when everything is switched off. No lights ie sidelights and headlights work. Cheers Chris 300tdi Defender 90 |
if you have a few spare 60 a fuses, you could pull the relay out, put a new fuse in, if it blows its not the relay!
edit, i think lol My 109 thread my youtube channel |
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge three main drawing for 300 tdi good luck Last edited by dorsetsmith on 10th Jan 2016 5:42pm. Edited 2 times in total |
Good thinking barman.
Ran out of spare fuses after the first one doh. Nowhere to get any here on a Sunday. Thanks very much everyone think I'll go to the pub and think about it for a while. Cheers Chris 300tdi Defender 90 |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20612 ![]() ![]() |
It may be the starter cable between the relay and starter.
It may be shorting due to some kind of damage and this blowing the fuse. It won't blow until you give it power by going to start it, it'll just blow over again with not starting intention at all just a fuse blow. I'd give it a contiuity check on the live feed and a check between the live feed on there to chassis ground. (Make sure battery is disconnected and everything off first) If there is any reading between the starter live from relay to earth then there is a short. Diagram should help above no end. |
^^Agreed, if it is blowing as soon as you replace it, rather than when you turn key to pos 3 its likely to be a cable! My 109 thread
Check the main power cable running out of the battery box to the starter if this cable is chaffed/loose it could be arcing. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
