Home > Puma (Tdci) > fuel filter click |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6298 |
Just pondering on how loud / obvious the click should be?
When I fitted fuel filter I could not hear a click....its not fallen off so I guess it's ok but when I come to fit next filter should there be an obvious click? |
23rd Mar 2014 11:32am |
Good. It's supposed to (I think). At least that's how I've interpreted the pictogram on the side of the filter.
23rd Mar 2014 12:07pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
They don't 'click' as such [no obvious noise] .. you just 'feel' it sort of latch into position Guns and Landrovers .... anything else is irrelevant.
23rd Mar 2014 12:45pm |
Right... removed and refitted fuel filter?
Still not completely sure if it's 'clicked' into position correctly or not? Anyhow when I removed the filter I gave the housing from below a good squirt with magic spray (wd40). Not sure if this was a good idea o not but doesn't seem to have done any harm? Drive to work this morning was non de script but the drive was mechanically great... everything seemed just right |
6th Jan 2016 5:21pm |
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4660 |
I use a strap type filter wrench to loosen it as I find it awkward to get a good grip on the filter with the wheel in the way. I place a tray underneath to catch the diesel spillage. I fill the replacement filter with diesel then lie underneath and put it in place by lining up the two lugs and then twisting it by hand. Then I use the strap spanner to give it a final twist as I find it very difficult to get sufficient grip by hand. 1982 88" 2.25 diesel
6th Jan 2016 5:50pm |
Thanks spud..not just me that struggles by hand.
6th Jan 2016 6:32pm |
