Home > Camping, Caravanning and Holidays > What trailer are these? Sankey mk2's?
Stacey007
Hello
Found this and I think its a sankey MK2, seller doesn't know just saying its a Sankey and not the narrow one. So I guess a wide track?
folding tail gate, drum brakes?
then this one what model is this> Guess this has disc brakes, whats the other lever near the front of the chassis?
Thanks
Post #488833 5th Jan 2016 1:47pm
Brewstop
United Kingdom 2002 Defender 110 Td5 CSW Zambezi Silver
At a guess, it's a Wide Track Mk 3
 Sandy
Post #488842 5th Jan 2016 2:13pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
1st one looks like a wide track MKII as it has no master cylinder for the brakes so must have the drums, not sure about the 2nd, it looks like a MKIII as it has the master cylinder. On the 2nd trailer you can see the hand brake lever underneath but i'm not sure what the red handle is on top, looks like some kind of hydraulic lever.
Post #488845 5th Jan 2016 2:20pm
Caterham
I think the red hand is for rotating the jockey wheel away into the horizontal stow position. (why are you asking about the red handle...doesn't it say) and more to the point why have I answered Embarassed Laughing
looks like mine which I am lead to believe is a Wolf / Mk 3 wide track?
Post #488853 5th Jan 2016 2:53pm
Scoobeenut
The red handle on the 2nd trailer looks like some kind of hydraulic pump or lubricating pump handle.
Post #488871 5th Jan 2016 3:33pm
JOW240725
They both look pretty tidy. I can't help which mark they are but would it be rude to ask what sort of money these are going for?
Post #488892 5th Jan 2016 4:36pm
Treebeard
United Kingdom 2005 Defender 110 Td5 CSW Chawton White
The first trailer looks strange. It does not have the normal Sacol damper of the mark 2 and there is no sign of the mechanism that is actuated by the end of the damper to apply the brakes. Nor the hand brake lever. Do the brakes actually work?
Post #488968 5th Jan 2016 8:13pm
Treebeard
Sorry ignore the above - I think that it is all there but difficult to see. Reckon someone has fitted the MK 3 Bradley damper to the mark 2 - fine as long as it all works.
Post #488972 5th Jan 2016 8:17pm
Stacey007
Jow
Sent you a PM.
Thanks all, seems there's a lot of choice, then I even spotted a penman... however it has no tail gate and a lot more money.
Pretty sure a sankey will do for my needs just finding one !
Thanks
Post #488981 5th Jan 2016 8:44pm
Boyd
France 2003 Defender 110 Td5 SW Zambezi Silver
First definitely a Mk2 widetrack, second definitely a mk3 wolf with an additional hand hydraulic pump or similar. Last time I saw one of those on a trailer it was a hydraulic tilt bed?! Could someone have modified a mk3 into a tipper? Shocked 2003 Zambezi Silver TD5 110 XS SW overland prepped....
2004 Santorini Black TD5 110 XS SW left hooker for sale!
2004 Alpine White TD5 110 left hooker (work in progress)
Post #488993 5th Jan 2016 10:00pm
Scoobeenut
Stacey 007 I saw this Penman today on Witham's website that maybe worth a look http://whitelabel.globalauctionplatform.co...enturl=wca
Post #488996 5th Jan 2016 10:05pm
Stacey007
Scoobeenut
Many thanks I spotted that, but £500 with reserve not met, I reckon that will be £1500 which is too strong for what I want it for and also it looks as though it has a fixed tail gate,
Looked very good condition though
Thanks for sharing !! Very Happy
Post #489009 5th Jan 2016 10:26pm
Stacey007
Boyd
Think your bang on as the 2nd one has a added top that seller states opens hydraulically... hence what the lever must be for?
I'm not keen on that part so would remove the top bit anyway (the checkered bit)
Post #489012 5th Jan 2016 10:29pm
Boyd
If you're trying to decide between a mk2 and a mk3, think about what you're going to tow it with and how. A mk3 was designed to sit level or ever so slightly nose heavy behind a defender wolf which has a 1.5" lift and the nato hitch was on the cross member.A widetrack mk2 designed to go behind a SIII at I believe std ride height with a cross member mounted hitch which has s somewhat lower. As the last thing you want is a light hitch (which would happen with a mk2 on a lifted defender) as it'll make it prone to snaking particularly when loaded. If however you have a NAS rear bumper and a std height defender a mk2 would actually sit better (although can't find a picture to confirm).
Thumbs Up 2003 Zambezi Silver TD5 110 XS SW overland prepped....
Post #489076 6th Jan 2016 6:23am
Stacey007
^ Hello
I Have a std Defender 110 (normal height) and probably will go for a Mk2 Sankey as these seem more common. I assume with a drop hitch I can get the correct height as I do want it to sit level.
I could always remove the rear wheel and put the nato hitch directly onto the cross member (would rather not have to)
Its just for camping gear and probably put the bike it it also (on top on a rack)
Would this set up be level?
Thanks
Post #489165 6th Jan 2016 10:58am
