Home > In Car Electronics > Security Upgrades |
Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678 |
PM sent
5th Jan 2016 6:59am |
Striker Member Since: 04 May 2013 Location: Yorkshire Posts: 127 |
Could you also pm the details please.
Also whilst I have the rear tub off my Defender can I modify the fuel system. Re, a fuel cut off valve or electrical cut off switch or both without causing airlock problems. Cheers Andy Never Knowingly Understood |
5th Jan 2016 7:31am |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7903 |
I too am very unsure on what and how much security to get. I know you need layers but its a fine balance between lots of security and everyday usability. I don't' want to spend 10 minutes just to unlock/disable/remove to run 10 minutes down the road. Also the more you add the more to go wrong/cause conflict?!?!
If only people would stop stealing them!! It's mine and I want to keep it thank you!! |
5th Jan 2016 1:30pm |
claydiggermud Member Since: 11 Jul 2015 Location: west country Posts: 86 |
Can you also pm me please.
Thanks claydiggermud |
26th Jan 2016 8:11pm |
Check out our thread started today
26th Jan 2016 8:13pm |
PM to me also, please... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
26th Jan 2016 11:11pm |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 |
The easy st way i can think off is to put a relay between the 2 signal resistors of the E-throttle.
http://www.velleman.eu/products/view/?coun...;id=375928 or use it to interupt the main relay , or a few injectors. Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
27th Jan 2016 12:01am |
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 600 |
I would appreciate a PM on simple TD5 electrical security options.
30th Jan 2016 11:23am |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
can you pm me also! |
30th Jan 2016 1:21pm |
andre.prum Member Since: 24 Feb 2014 Location: Bridel Posts: 8 |
Tanks for sending PM also for a Defendr 2.4 Puma year 2011 and a Defender Puma 2015
31st Jan 2016 11:38am |
Fiebre Member Since: 24 Jun 2015 Location: Sabadell Posts: 23 |
Thanks to sent me a PM also for the PUMA 2.4
Regards |
31st Jan 2016 12:38pm |
richardg Member Since: 17 Dec 2012 Location: Cumbria Posts: 30 |
Could you send me a PM also ? Many thanks
3rd Feb 2016 8:33pm |
simonpuma90 Member Since: 16 Nov 2008 Location: south wales Posts: 472 |
And me please
3rd Feb 2016 10:18pm |
williamthedog Member Since: 29 Dec 2012 Location: south wales Posts: 3441 |
Could you send pm about 2.4 to me as well
4th Feb 2016 8:18am |
