Home > Td5 > Coolant Leak. Cracked Head? |
kweese Member Since: 28 Apr 2015 Location: Van Posts: 62 |
I recently changed the Radiator my TD5. Its a 2000 with the 10P engine. It looks like the Head has been changed before from markings I see that it came from a wrecker or Breaker. It's been cold out and the last time I parked, I noticed a pool of coolant. I looked all over and I found the source is somewhere as in the Pictures.
Click image to enlarge I'm hoping it's not a cracked Head. I have no indications of excessive white smoke coming from the tail pipe, no lost power, and my oil is not creamy. Are there any hoses in this area that could have cracked or have loose clamps? |
3rd Jan 2016 5:15am |
Coolant loss is excessive. It's drizzling out not just a slow leak.
3rd Jan 2016 5:19am |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 158 |
Hard to tell from an estimated location, but it might be the water jacket core plug that is leaking. If I didn't remember wrongly, there are 5 around the engine block. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island.
3rd Jan 2016 8:44am |
fuel cooler leck worth investigating
http://www.discovery2.co.uk/fuelcooler.html |
3rd Jan 2016 8:55am |
I checked the Fuel Cooler. It's not that. It looks like it is coming out from under intake manifold. What could this be?
5th Jan 2016 9:12pm |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 332 |
Could be freeze plugs on the block ? Unlikely to be a cracked head I would have thought.
5th Jan 2016 10:18pm |
5th Jan 2016 10:19pm |
Where are they? It's on the passenger side of car on a Left hand drive model.
5th Jan 2016 10:21pm |
Hi folks.
Click image to enlarge If this is the case. What are the steps to get to this? Remove manifold, what else? Please help. |
6th Jan 2016 6:53am |
I got this picture from another site.
Also, would it be advisable to check the manifold for trueness and buy new screws? |
6th Jan 2016 6:57am |
My mistake again. The picture I found is for the other side of the engine.
6th Jan 2016 8:03am |
