![]() | Home > In Car Electronics > Driving / spot lights |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Possible - lights earth through the mounting, and you have supply cables for pos and neg around the wrong way [so in effect you are giving it a direct short] ?
Just an idea .... Guns and Landrovers .... anything else is irrelevant. |
Myers Member Since: 07 Dec 2011 Location: Wiltshire / Sailisbury Plain Posts: 156 ![]() ![]() ![]() |
Thanks for the quick reply.
The lights are made from a plastic type material, so do not earth via the mounting. It appears not to matter which way around the connections are as the bulb has two prong fittings and fits either way. Myers - Somewhere on Salisbury Plain Puma 90 Hardtop (XS Spec) |
