- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Vitesse
Thanks Eric... I bought the flebay loom and it didn't work on "flash" when using dipped beam. I bench tested it first. It could be simply modified but I wasn't happy with the design (physical) of the loom and made a complete new one . Slightly OCD in that way!! I used new relays fitted neatly in the fuse box under the drivers seat and used appropriate sized cables to feed back to the lights... All run in flexible conduit from the fuse box and forward to the n/s front wing area. Also supplied some additional spare wires for future electrical works including spot lights etc.... The overall effect was an increased voltage supply to the lights which has made a small difference. But the main issue is of course to stop the light switch from melting... 2015 90 XS Santorini Black
30th Dec 2015 12:46pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
