Home > Td5 > Front door seals (surround)
excossack
Tried to re-align the drivers door to make the hip part of the door line up with hip part on the B pillar post.
Got this a little better but with the door seal in place, the door still is not flush with the B pillar.
There appears to be a hard rubber insert in the door seal where the hip is.
Is this correct? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #476779 27th Nov 2015 6:50pm
dorsetsmith
LR Door seals or Blue box parts seals ?
LR seals rubber softer, blue box seals harder rubber
also make shore rubber seals are fitted properly
Post #476786 27th Nov 2015 7:14pm
Retroanaconda
Yes. It prevents the seal collapsing.
The close position of the door is set by the striker position. If you move it further inboard the door will close tighter against the seal.
If your seal is non-genuine it will be too stiff and the door will not close fully.
Post #476789 27th Nov 2015 7:17pm
excossack
Not sure if the seal is genuine LR or not, always been on the car since I purchased it 5 year ago.
Is there an alternative to genuine LR seals, which I guess are not cheap? 1999 Defender TD5 110
Regards
John M0VAZ
Post #476811 27th Nov 2015 7:42pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
A genuine door seal has a thicker rubber insert inside the the hollow rubber seal at that point. If it is in place it is likely a genuine seal. Yes it is supposed to be there. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #476986 28th Nov 2015 12:55pm
Retroanaconda
Aftermarket seals have the rubber insert too.
I've never found anything other than genuine ones to be of satisfactory quality. To the extent that 20+year old genuine seals were better at the job than brand new Britpart seals.
Post #476995 28th Nov 2015 1:37pm
excossack
Replaced the passenger and drivers door. The passenger door shuts the same as before and has a bit of spring when opening. The drivers door needs a bit more assistance shutting.
What I have noticed is with the door seal removed the door aligns better with the hips but the top of the door is a good few MM in at the top i.e not flush. Maybe this is causing some issues with shutting the door.
I have 3 spacers between the top door hinge and the door. So I was thinking of removing a space or two to see if the door aligns better.
Is there a certain number of spacers needed? 1999 Defender TD5 110
Regards
John M0VAZ
Post #486575 29th Dec 2015 1:51pm
Retroanaconda
Add/remove shims to get the door flush with a pillar at the leading edge.
If the top of the door up near the roof is slightly out but the door frame at the waist is fine then the only solution is to gently bend the door too the correct way. I find a knee against it and heaving it works well. Just don't snap it off!
Post #486629 29th Dec 2015 5:03pm
excossack
Leading edge flush with a pillar or the A pillar? 1999 Defender TD5 110
Regards
John M0VAZ
Post #486640 29th Dec 2015 5:34pm
Retroanaconda
With the A pillar, apologies.
Post #486657 29th Dec 2015 5:58pm
excossack
Thanks. That makes more sense in my head now. 1999 Defender TD5 110
Regards
John M0VAZ
Post #486659 29th Dec 2015 6:02pm
Screbble
Please let us know how it goes, and post some pics if you get chance excossack. Thumbs Up
Do you intend to purchase new door seals? If so it'd be good to hear from others if there are any decent (softer) aftermarket offerings that are better than the blue box product yet cheaper than LR.
Mine look like the originals and have seen better days, however this thread has made me think twice about some of the less expensive options Wink
It sounds like you have a plan. Best of luck!
Post #486771 29th Dec 2015 11:01pm
excossack
I took a chance and purchased door seals from LRi Solutions via their ebay site.
When I get a break in the weather I might venture back outside and have another look 1999 Defender TD5 110
Regards
John M0VAZ
Post #486859 30th Dec 2015 12:34pm
rallysteve
I fitted bearmach seals a while back. Fitted well and still nice and soft. Doors dont touch them at the top but thats a different issue! 02' 110 TD5 Double Cab Rebuild Thread
Post #486868 30th Dec 2015 12:58pm
excossack
Leading edge on both doors flush with A pillar 1999 Defender TD5 110
Regards
John M0VAZ
Post #487169 31st Dec 2015 8:53am
