Home > Puma (Tdci) > 2.4 Tdci on its last leg ?
furianer
Switzerland
Good evening, long time since I've used this forum, guess to busy fixing Landys of all sorts.
One of my customers got me this nutcase to sort out for a x-mas present
Anyone with the same engine noise out there
Defender 2007, stock standard, 214 000km
Oil pressure ok, crank case pressure ok, slightly more pressure in coolant system than others
Serviced regularly
Can't wait to hear what others think
Richard
Post #485577 26th Dec 2015 5:08pm
Scoobeenut
United Kingdom 2010 Defender 90 Puma 2.4 SW Santorini Black
Sounds like split hoses or something leaking somewhere?
Post #485592 26th Dec 2015 6:03pm
Sounds to me like someone has replaced the TDCi with an 8-cylinder Gardner!
Post #485606 26th Dec 2015 6:32pm
furianer
Switzerland
Thanks scoobeenut
But no cracked hoses or external leaks.
Anyone had a blown head gasket between bores on a 2.4, just crossed my mind
Black wolf, it does sound a bit like a Gardner, but not as solid
If a engine conversion ISUZU. 4bdt1t for me. Wink
Post #485616 26th Dec 2015 6:58pm
ickle
There was a post on here reference a potential egr cooler leak allowing the coolant to pressurize?
Post #485670 26th Dec 2015 9:51pm
furianer
Switzerland
Ickle thanks, but a leaking EGR cooler wouldn't be responsible for this unhealthy noise
Here is another little clip
Post #485713 26th Dec 2015 10:58pm
ickle
Piston cooling jet fault?
Post #485723 26th Dec 2015 11:08pm
Eau02467
Cracked exhaust manifold?
Post #485845 27th Dec 2015 1:48pm
furianer
Switzerland
had a bit of a look see this evening,
injectors leak off test, runs with the comp hooked up
injectors out
endoskop showed lovley looking pistons. bores. spray pattern and valves, expected a lot worse with this milage
Valve cover off
this could be the answer or at least one of them
this little clip shows exhaust valve Nr. 3
cam lob and follower. hard facing worn off, follower out of round
nice evening to all of you, thanks for all your inputs
Richard
Post #485905 27th Dec 2015 5:47pm
