Home > Series Land Rovers > Power Outlets |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2762 |
The Series 3 (like I understand 1s and 2s have) has the red and black separate 'pin' style accessory power outlet.
Does anyone know where I can buy connectors to fit these? I want to wire up a USB port or something similar to power small devices. I also understand these are not fused? Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
23rd Dec 2015 8:05pm |
SailingTom Member Since: 19 Nov 2013 Location: ESSEX Posts: 1722 |
If you look up land rover military light its the best way to get something with that connector. I long term borrowed one and wired it to a potable 12v cigarette socket in a hidden portable box.
meant i could power a satnav, like you say only use it for small things though. this is the only thing i could find with the socket. admittedly thats an expensive one, but they come up on ebay aswell much cheaper. http://eshop.lmslichfieldltd.com/lamp http://www.ebay.co.uk/itm/like/27188576660...mp;ff13=80 |
23rd Dec 2015 10:46pm |
Why not just add one of these and then you can just plug your USB straight in. You can put it where you like. You could allways source a similar product from one of the forum sponsors, I'm sure Brendan(aka 4x4 Overlander) would be able to sell you one.
http://www.ebay.co.uk/itm/12-24V-LED-USB-C...SwjVVVu13F |
23rd Dec 2015 10:52pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3750 |
Those are the unit that can with the series etc,, Certainly dear !!! I got 2 or 3 for Ł20 for the Series 1 back June ish time,, As Tom says, they do come up cheaper that that link Save a search for RTC4784 California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
23rd Dec 2015 11:15pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1768 |
If anyone has a pair of calipers and could measure, that looks like a 2mm banana plug may fit.
24th Dec 2015 12:24am |
Thanks for all the advice, people. Spot on as usual!
Uncas, very kind of you. Let me know if you come up with anything and we can come to some arrangement. No worries if not obviously! Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
24th Dec 2015 12:49am |
uncas Member Since: 22 Nov 2012 Location: Wentworth near Rotherham Posts: 340 |
If I find it David you can have it for free its been there over 25 years I don't think that I will be wanting to use it.
Uncas |
24th Dec 2015 1:07am |
Cheers, well let me know if you find it anyway and we can come to some arrangement if so. Very kind of you, thanks. Cheers, David
24th Dec 2015 1:28am |
Barneyboy Member Since: 19 Nov 2014 Location: Exmoor Posts: 1627 |
Hi failing that I got mine from Maplins just checked and they still sell them Maplins Banana Plug code L87AZ Ł2.49 for the pair Paul Tash n Barney
24th Dec 2015 7:10am |
Great thanks! Cheers, David
24th Dec 2015 8:53am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17489 |
The plugs were widely used in vintage days and specialist suppliers of vintage electrical automotive parts usually sell them (Paul Beck, Holden, etc)
Remember that although the sockets are colour-coded, there is nothing physically preventing incorrect insertion. There was a similar plug/socket in use on quality pre-war cars where one pin was a larger diameter than the other to prevent this. These look very similar but won't fit the LR type. |
24th Dec 2015 9:11am |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
www.thexmod.com
http://www.thexmod.com/sub_catagory.asp?su...ffset=1344 Scroll to the bottom |
24th Dec 2015 4:50pm |
PCA42 Member Since: 15 Jun 2014 Location: Church Stretton Posts: 468 |
I fitted a surface mount 12v socket on the side of the dash binnacle on mine, with the wiring piggy backing off the original twin sockets so there is no damage left if removed at a later date. However, this may not be advisable because the original twin sockets are permanently live and not fused. Pete
2010 Discovery 4 GS TDV6 1972 Series III 88" 2.25P |
24th Dec 2015 11:51pm |
V8_Disco Member Since: 19 Dec 2015 Location: East Yorkshire Posts: 37 |
Shhhh I fitted a fuse behind the binnacle on the truck before the stage 1 ... Looks 100% but loads safer
25th Dec 2015 2:01am |
