Home > Td5 > TD5 buying advice
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
TD5 buying advice
Hi,
Possibly off topic, but I am considering a TD5 Discovery to go along with my Puma 90, but I don't know how much is too much wrt mileage on this engine.
Would you reckon 165k Miles is a lot on a TD5? (on a Discovery, so it's a higher power output than the Defender).
Post #484750 23rd Dec 2015 9:35am
Depends on the model year.
Pre '02 had the usual head movement problems...
The biggest thing is rear chassis corrosion on uk cars, check where the rails are at the lowest point ahead of the rear crossmember.
Rear airbags can be replaced with coils very easily. I like td5 discos and would have one myself, Japanese imports are the best.
Post #484772 23rd Dec 2015 10:49am
yetiman45
England 2005 Defender 110 Td5 CSW Blenheim Silver
Great engines, will go on forever with regular oil change. Chassis made from kit kat wrappers, as mentioned check for rot.
Post #484774 23rd Dec 2015 11:00am
grumpy old git
I sold my last Td5 D2 with 230k on it, lost rather than burnt oil and always walked the MoT emissions test. Chassis disintegrated at the rear, chap who bought it put in ¼ chassis & some patches, still going strong on original gear & transfer boxes 👍
Post #484889 23rd Dec 2015 6:27pm
o4dn
Thanks all, these are really useful inputs! Thumbs Up
Post #485106 24th Dec 2015 12:58pm
adseybear
Canada
Mate of mine bought a td5 disco with 180k on the clock, runs like an absolute dream, gbox feels a million times better than my defender one with half the mileage on it.
Now been tuned and pulls like a train. So in short, as long as its got a good service history and no problems when you go to look at it, dont be put off by mileage.
As you've already seen, the biggest issue is rear chassis rust, but nothing you cant chop out and weld in a new rear section. 2003 Defender 90 Td5 CSW Belize Green - "Betty"
1958 Series IIA 109 Station Wagon - "Randolph" - Awaiting Restoration
2019 Jeep Wrangler JL Rubicon - SOLD
2006 Volvo V70 D5 - Ocean Race Edition, SOLD
2003 VW Passat Estate 1.9TDI - SOLD
2008 BMW 320D M Sport Estate - SOLD
2001 Defender 90 Td5 Hard Top - SOLD
Post #485116 24th Dec 2015 2:09pm
You can now get galv replacement chassis for the Disco2. It's more difficult to swap than a Defender though since the body must be lifted complete.
I love my TD5 Disco, even at 200k miles! The main issues to watch for are the chassis rot above the rear axle, the usual TD5 clutch judder, leaks from the ACE, and air suspension issues. My advice go for one with 5 seats (so coils all round) that hasn't has its ACE removed. Oh, and the headlinings sag eventually as the foam layer breaks down. All these things can be fixed fairly easily though.
Great vehicles. In fact, I think history will prove the TD5 Disco2 to be one of the all-time greats!
Post #485118 24th Dec 2015 2:18pm
o4dn
Humm, that's more and more tempting, the one I am considering (I haven't seen it, it's quite far from where I live) is a 2004, looks immaculate, never been off road and has coil springs (so no ACE issue) and the owner says it's always been kept inside and there is absolutely no corrosion neither on the chassis nor the body,
The clutch has been changed recently, as well as the head gasket (which sounds.. odd). Owner also mentioned on the phone that ABS light comes up from time to time even though he had the ABS sensors replaced.
He also said the fuel pump is noisy but he's providing a replacement part (but not fitted as the old one's still working...)
And the pictures he sent me look absolutely stunning! Full leather interior Mr. Green
Post #485160 24th Dec 2015 5:51pm
Unless it is poverty spec (which won't have leather) it will have ACE. Coils however mean you have the advantage of not having the rear air suspension, which can be troublesome and really offers few advantages.
The ACE was an outstandingly good system and the only real problem is that eventually the pipes can rust and leak. They're not cheap to replace, but not difficult either, and do last a long time. I bought my D2 new in '02, it's done 200,000 miles and I have had to replace 1 ACE pipe last year. That isn't bad.
Provided that you have a Nanocom or similar, a D2 is just as maintainable as a Defender. The ABS warning light may be caused by the FOS ABS sensor wiring, if it is original. There is an issue with the connector in the wheelarch and replacement sensors have long leads to be taken straight to the SLABS ECU under the glove box, doing away with the connector.
Post #485173 24th Dec 2015 6:22pm
o4dn
Ah, yes, you're right, it's the one without rear air suspension ...
Now, for the same price, if you were to chose between a low mileage (80k) 300Tdi Disco and a much higher mileage (165k) TD5 Disco 2, which one would you take? That'd be for gentle greenlaning.
Edit: Yes, I do have a Nanocom actually, all I'd need is the additional software licences for the TD5
Post #485180 24th Dec 2015 6:40pm
V8_Disco
1989 Defender 110 V8 Petrol SW Auto Bonatti Grey
Td5 amazing I miss my v8 disco 2 for comfort ... Watch out for the 3 amigos and rust as already covered
Post #485185 24th Dec 2015 7:06pm
For me the Td5 would be the one, but others may have the opposite view. It's a personal thing!
I honestly do believe that the Td5 Disco is one of the all time greats - good looking, exceptionally good at almost everything, and sophisticated without being overly complex. The complexity of its successors let them down.
Mine's taken me over 200,000 miles on and off road and has never let me down. It's a brilliant towing vehicle (my personal record is towing a 140 tonne load, although there was a strong smell of hot clutch, and it was only for about 30 metres), and is superbly comfortable.
Post #485243 24th Dec 2015 11:27pm
ozzy57
2002 Defender 110 Td5 CSW Alveston Red
Td5 every time, and personally, I'd go for one with airbags on the rear. I've had ones with bags, and with coils, much prefer the bags as long as the system is looked after and well maintained. It wasn't me!
Post #486192 28th Dec 2015 12:05pm
o4dn
I am going to see the Tdi tomorrow.
Reason I'd fancy the Tdi more is because it's very similar to the Defender, same axles, same transfer box with central locking diff, etc.
I see the Disco Tdi as a more comfy sort of Defender 100", whereas the TD5 is from another generation with electronics all over the place, ABS, SRS, ETC, ACE [insert your favourite 3 letter acronym here].
But we'll see tomorrow, I just hope it's not yet another one of those rust heaps... it's more than 400 miles away Big Cry
Post #486214 28th Dec 2015 1:25pm
Freypal
United Kingdom 1992 Defender 90 200 Tdi HT Portofino Red
Sold my td5 d2 with 180k on the clock. Engine was perfect, flew through MOT emissions and pulled strong. In the 5 years I owned it I did the following work;
3 ACE pipes replaced at around £150 each.
Fuel pressure regulator
Rear chassis legs welded
Crank position sensor replaced
Rear hub assembly
When I sold it the gearbox was on its last legs, although to be fair when I bought the car it wasn't great so it soldiered on a long time.
Fantastic truck, I'm actually considering getting another. They're just a comfy and quieter defender.
Post #486514 29th Dec 2015 10:30am
