![]() | Home > Puma (Tdci) > running noise |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I have a strange clicking sound as well. Sounds as if it is coming from behind the dash, almost like a relay opening and closing. Not to bothered though, if you turn the stereo up it goes away............
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2464 ![]() ![]() ![]() |
NOt a lot of details, but try to push a bit the brakes. If it goes way, then are rattle brake pads. Old topic.
If it close to the gerbox-tbox area, then check on UJis.......or it is a rattling clutch (springs are gone). Puma 110" SW ............................................................. Earth first. Other planets later |
digger Member Since: 12 Dec 2010 Location: dorset Posts: 10 ![]() ![]() |
thanks for your help guys . have now solved the problem. clicking was loose wheel balance weight can now turn the raidio on.
