Home > Maintenance & Modifications > Retro Fitting Aircon
Snowy90
United Kingdom 2008 Defender 90 Puma 2.4 XS CSW Fuji White
Hi,
Apologies if this has been covered to death but did a quick search and couldn't find anything.
I'm considering getting all the parts from a breakers and retro fitting it to my 2008MY 2.4TDCI
Firstly Any advice or maybe point me in the direction of a definitive thread!
Secondly does anyone have a parts list so I can be sure I get everything I need?
Thirdly Anyone already done this modification>
Any help appreciated.
Thanks
Post #482794 16th Dec 2015 5:24pm
grafty99
I think Devon 4x4 do a complete kit Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #482796 16th Dec 2015 5:33pm
^^^^ I believe so too. Circa £2k IIRC.
Only thing you cannot do as I'm sure you are probably aware is deal with the gas and pressurise it.
Specialist qualified job.
Rarely ever need it here in the U.K. And I don't have it myself.
Post #482806 16th Dec 2015 5:54pm
T1G UP
I'd phone around the breakers. All partsxare available and easy to fit. I love my a/c keeps the windows clear in winter and chilled in summer.
Post #482989 16th Dec 2015 10:46pm
It'd need de-pressurising first though, all the same a breakers isn't a bad ideal so long as everything was straight. Thumbs Up
Post #482996 16th Dec 2015 11:08pm
Swac3
I've finally got around to ripping mine out, just the Cab portion for now but ultimately I'll rip out the under bonnet stuff and swap in a non A/C front nose/grill. Its an old 1999 TD5 unit and ive never had need of freezing my knees yet so all it does is block the footwell heater in the winter and take up legroom for the PX. 3 Landrovers
Post #482999 16th Dec 2015 11:31pm
Snowy90
I must admit, im a fan of opening the window in summer, defenders design is great as the air doesn't blow in your face and mess up your hair!
Its more in winter, kids Dog all annoyingly breathing and steaming everything up you only need one wet coat!
OK so list of parts
1) Air con nose/grill I have a KBX grill Do I just need the extended metal surround.
2) Radiator with AC attachments
3) Compressor
4) Compressor Bracket and bolts
5) Belt- Question anyone have a pic of where the belt is driven from??
6) Blower Unit in engine bay I believe or is it behind dash?
7) Switch/ wiring loom
Cool Regass
Probably not exhaustive list of parts, I have seen breakers parts circa £600 which doesn't seem that bad assuming its a DIY job if your handy with the spanners.
Post #483039 17th Dec 2015 10:07am
I've retrofitted them before now. The compressor bolts to the engine and you replace the existing belt with the longer version.
Post #483042 17th Dec 2015 10:12am
ajps72
2001 Defender 110 Td5 SW Chawton White
Hello, I fitted a different type of aircon to my td5 110, different country though.
1.- I didn“t need the new grille, the condensator fitted well between the radiator and intercooler
2.- I used a general brand compressor, which is longer and have to be moved when changing the centrifugal filter Embarassed
3.- finally the evaporator is fitted at the back, so it doesn“t take knee space Augusto
Defender 110 TD5 2001
Discovery 4 TDV6
Post #483073 17th Dec 2015 12:27pm
Pickles
We certainly use the A/C in Gracie, in summer,...and winter.
Just a few days ago we were cruising around in beautiful 38C (it's gonna be 44C this w/e!) weather in the Aussie countryside,.....definitely would not be without A/C here!
So major use is in summer here, but it also comes in handy in winter for demisting the interior.
Pickles.
Post #483209 17th Dec 2015 9:20pm
