Home > Maintenance & Modifications > TD5 ecu relocation |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
You can get it here without the extensions. You need to extent the highlow range wire and the difflock wire.
This is not my picture but mine is installed similar. It is bolted through this Alu plate. you can see the nuts. Click image to enlarge Before the new plate installation. You can see the connectors. Click image to enlarge Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
16th Dec 2015 4:51pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 617 |
In Discovery 2 I have moved the ECU from engine compartment inside, close to the other ECUs. Some wires I have just moved, to some I have soldered additional wires. It is easy, just make it step by step - wire by wire. And use heat shrinking tubes to cover the solder joints. Signal from crank position sensor is fed by a shielded twisted pair - I made it with 2 wires and shield from a coaxial cable. Covered by heat shrink tube. "Drobek" = The Small One - Discovery 2, "BlufÃnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
16th Dec 2015 5:23pm |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 845 |
Di will add a pic once daylight returns,
But I used the loom extender job by, and mine sits on th dog guard right behind the headrest, way out of the way of water and oil ingress, Only downside - it's £200 and they click rather a lot ( don't hear it onc rolling though ) |
16th Dec 2015 6:14pm |
CDN38 Member Since: 14 Nov 2014 Location: Courtenay, BC Posts: 729 |
Here's an option to go under the cubby, just past half way on page 1. This truck is a fantastic build...
http://www.defender2.net/forum/topic32405.html |
16th Dec 2015 6:40pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
That's great I d8dnt think you would be able to extend it that far. Does it restrict how far you can put your seat back? 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
16th Dec 2015 7:34pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
I once owned a Td5 90 SW that was one of several prepared by SVO for a journalists off road jolly somewhere in Spain. Amongst a number of other modifications they moved the ECU to the top of the bulkhead behind the drivers seat using an extension loom. The vehicles and event appeared in one of the rags at the time including photos of them crossing rivers with the water well up to bonnet height - as witnessed by the amount of crud I subsequently discovered behind the dash. Steve.
16th Dec 2015 8:25pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
I moved Pam's up behind the passenger seat. No bulkhead but have a roll cage cross behind the seats and a dog guard so the ECU is mounted on a plate attached to the cage and the floor.
This is using the standard loom, no extenders. As the previous post, you just need to extend the diff lock, hi/lo and transmission brake wires. I drilled suitable sized holes in the floor behind the seatbox and used the original grommets. Looms rerouted... Click image to enlarge ECU and fuse box mounted... Click image to enlarge Cover made to protect wiring from coats etc... being stuffed down the back of the seat... Click image to enlarge If you have a bulkhead behind the seats it's a LOT easier as you can just mount it to that. http://www.yorkshireoffroadclub.net/ |
16th Dec 2015 9:52pm |
Anderzander Member Since: 08 Feb 2011 Location: Lancashire Posts: 1000 |
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge I didn't alter the loom to do this. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
16th Dec 2015 11:38pm |
You can reach the bulkhead behaind the seats in the middle as the cables are on the left side off the gearbox and then go over the transfer box to under the right seat. The length that is used to get from the left side off the gearbox to the right seatbox is used to get behind the seat. Roel
17th Dec 2015 7:03am |
jasong4110 Member Since: 18 Oct 2009 Location: Henley On Thames Posts: 268 |
I had a box built for me out of all it cost less than £50 iirc, the whole relocation exercise is on my truck thread over on LR4x4 including the car files/drawings for the box. http://forums.lr4x4.com/index.php?showtopic=78984&page=2
Jason |
17th Dec 2015 8:56am |
ade666 Member Since: 10 Mar 2013 Location: crewe Posts: 50 |
holy moly. wasn't expecting this amount of replies. thanks guys lots of food for thought. I really like the muglo box thing from Australia but also your box, so to speak, Jason. looks like the new year is going to be busy 110 double cab in belize green.
Few little mods here and there 300 tdi disco |
17th Dec 2015 9:37am |
