Home > Maintenance & Modifications > Fitting the Nakatanenga Wheel carrier
Lorryman100
Spent 3 hours today fitting the wheel carrier whilst freezing my dangleberries off.
Post #47483 5th Dec 2010 4:38pm
BigRuss
looks pritty good.
I like how the weight is held by the rear cross member but still opned with the rear door.
Is is me or is there suddenly a lot of good products come from Nakatanenga just lately? Russell
2011MY 110 XS USW Black
Post #47486 5th Dec 2010 4:59pm
TC
Nice work Thumbs Up
Post #47487 5th Dec 2010 5:07pm
AndrewS
Thumbs Up 130's have feeling's as well you know Smile
Post #47489 5th Dec 2010 5:16pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
Nice one - and good write up Thumbs Up One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #47519 5th Dec 2010 9:33pm
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
good job Brian Thumbs Up
can i ask something?
what you earn in relation to, for examlpe mantec type wheel carrier Question
is it more reliable Question
by the way, can you put a pic with your hitch. if i am not make mistake you have a cover or it is red tow? www.newfoundland.gr
Post #47538 6th Dec 2010 6:59am
leeds
I think you will find that Brian use a ALKO type hitch. This has two friction pads built into the towing head/coupling attached to trailer/caravan. This makes the towing head bulkier then a non Alko head.
To accommodate this bulkier head/coupling the Alko tow ball has a longer neck.
If you use a Alko coupling on a non Alko tow ball and go into a tight turn/jack knife you trap the Alko coupling/head and break the cast ali pieces on the Alko head.
Guess how I know?? Whistle Whistle
Now I have deduced all that from the red triangle on Brian's tow ball cover. Now cue Brian to either confirm my theory or make me look like an idiot! Rolling with laughter Rolling with laughter Rolling with laughter
Brendan
Post #47542 6th Dec 2010 8:38am
Can you still get a jack in the OSR jack socket with this fitted?
Post #47543 6th Dec 2010 8:38am
Lorryman100
Guess how I know??
Yep, leeds is spot on. It is an ALKO tow ball which is longer than a standard tow ball to accommodate the alko stabilizer hitch. As the hitch acts with stabilizer pads to reduce the snaking action of the trailer the tow ball must be kept clean and free from grease hence the fancy cover.
pouf wrote:
good job Brian
is it more reliable
I wanted a spare wheel carrier that would remove the dead weight of the oem carrier and wheel from the rear door to save the wear on the hinges and from distorting the rear door, and to make hitching up to a trailer a little easier. I had looked at a couple of carriers and the mantec one still uses the hinges to hang their carrier which is not what I wanted.
The one sonic3d designed and is now being marketed through allisport is ideal if you dont tow a trailer fitted with an alko hitch as it interferes with the hitching process as it is fitted along the cross members length.
http://www.defender2.net/forum/topic1408.html
http://cgi.ebay.co.uk/NEW-AlliSport-Land-R...4cf2690baf
http://www.defender2.net/forum/topic4392.html
The nakatanenga carrier for me anyway, allows hitching and the cross member takes the weight instead of the door which was what I was after.
http://nakatanenga-tours.de/shop/article_R...RRHNAHI%26
I am delighted with the nakatanenga carrier as it is well made and for me looks just right on my landy Thumbs Up
I'm not sure! the hole is still accessible but you would probably need a longer Hi jack arm. As I dont use a HiLift jack I will measure how far the carrier extends if you want?
Post #47626 6th Dec 2010 8:12pm
Markb
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
Excellent write up and a nice idea to use a piece of chequer plate to smarten up the rear door. Instead of messing about cutting my own, can you advise who supplied it?
Tks.
Post #48244 12th Dec 2010 12:08am
Lorryman100
Mark, I got it from Nakatanenga along with the wheel carrier and a few other bits and peices as the postage is per order so it makes sense to order as much as you need for the one off postage cost of 23 euros.
http://nakatanenga-tours.de/shop/article_H...%2520PO%26
Post #48264 12th Dec 2010 11:14am
My Sonic one will be up for grabs soon cant get on with the damper thingy works fine on others just not mine Thumbs Up
Post #48268 12th Dec 2010 12:25pm
BigMike
Brian, what's inside the pivot? is it a polybush or does it need regular greasing and if the latter, is there a nipple? cant see on the pics
Post #54980 25th Jan 2011 5:52pm
nakatanenga
Germany
There are 2 conical bearings with a cap on top. Similar system to a axle wheelbearing. This is much better than a brass- or polybush, greasableand adjustable WANTED:
SII or SIII in max 1.5k
Post #54996 25th Jan 2011 7:39pm
nakatanenga
Germany
BTW: the wheel should be adjusted that the sidewall touches the carrier. This is much less stress to all components. WANTED:
Post #54997 25th Jan 2011 7:41pm
