Home > Td5 > Best Headlight bulbs |
jasong4110 Member Since: 18 Oct 2009 Location: Henley On Thames Posts: 268 |
Osram night breakers without a doubt, and although you say that you're not interested in a bowl upgrade the Chrystal wypac bowls work brilliantly with them.
The other thing that is well worth the effort is making a headlight loom, again huge difference. Jason |
12th Dec 2015 9:57pm |
rustyboxx Member Since: 08 Oct 2012 Location: Poole Posts: 548 |
^^^^^ :what he said: 2015 90 XS CSW TDCi - Beautiful
2007 110 XS DCPU - An itch that needed scratching 2005 90 Td5 XS CSW - Utterly brilliant 2001 Discovery 2 ES Auto - A phase I went through 1996 90 Tdi CSW - Uber reliable 1989 90 2.5 Petrol Hardtop - My first proper Landy 1985 Range Rover Vogue V8 -Troublesome |
12th Dec 2015 11:41pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
ive done none of the above, but what do yiu mean headlight loom? 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
13th Dec 2015 1:03am |
The problem with the original wiring is that Land Rover in their wisdom run the headlight circuit through the headlight switch before it goes to the lights. This means that the voltage at the light plugs can often be a couple of volts lower than the actual battery output.
The solution to this is to put a simple loom into the bonnet often powered from the live on the alternator, this is then fused inline before being connected to a waterproof relay/relays. The existing loom is unplugged and the O/S H4 plug is used for the trigger for the relay/relays and the N/S H4 plug is insulated off. By making this loom and connecting it in this way you ensure that the maximum amount of voltage is received by the headlights, and also take the load off the switch, which can prolong its life. These looms are also available pre made if your electricky skills are not up to it. Jason. I have no idea as to the quality of the item in this link but it gives you a good idea of what you need to create: http://www.ebay.co.uk/itm/H4-9003-Headligh...SwPgxVPf~f |
13th Dec 2015 1:38am |
Martin 01 Member Since: 13 Feb 2012 Location: East Yorkshire Posts: 502 |
Thanks for that, I'll get some ordered. |
13th Dec 2015 10:36am |
