Home > Puma (Tdci) > Question - illumination - heater controls
Can anyone tell me if the pictograms immediately above the slider for fresh/recycled air are meant to be illuminated by a bulb when the sidelights are on (2007 Puma County DC)? All the others (such as those for the blower slider) are, but not those, and I suspect that I may have a failed bulb.
Also, has anyone ever replaced any of these bulbs? The illumination on my air outlet control rotary knob thingy also tends to go on and off with road bumps, and clearly needs its connections jiggled, so I feel that the time to dismantle the centre section of the dash is approaching.
Post #45553 17th Nov 2010 12:27pm
Grockle
yes and sounds like a loose connection,to replace the bulb remove the facia containing the heater controls 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #45558 17th Nov 2010 1:36pm
Thanks, Grockle! Can anyone tell me a part number for these bulbs, and whether they are normal bulbs that might be available from somewhere like Halfords, or are they LR specials? If anyone can tell me, it would avoid the need the dismantle the fascia once to find out what I need and then again to fit the new bulbs.
Thanks.
Post #47784 8th Dec 2010 12:18am
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Hi BlackWolf,
I had to do mine soon after I bought it. I took out one of the bulbs and got replacements straight from a local motor shop
it was an easy job to do as I remember - as I'm not a mech by any means... i Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #47791 8th Dec 2010 7:37am
mse
These bulbs didnt use to be that expensive from a dealer Mike
Post #47796 8th Dec 2010 8:57am
pom
how is the facia removed ?
Pom
Post #47819 8th Dec 2010 12:52pm
To remove the fascia, firstly withdraw the radio, disconnect its connections and set it aside, then remove the two Torx-head screws below the window lift switches. The panel is then held by five clips; two at the bottom corners, two more at the top corners of the from face, and one adjacent to the clock. Starting at the bottom carefully pry the panel towards you, when the bottom has unclipped the remaining clips should give. The panel comes out hoizontally towards the rear of the vehicle.
Next, reach behind the panel and disconnect the connectors from all the switches (depending on model spec and equipment levels there may be connectors on some of the switch blanks too). When all are free, the panel can be set aside. (I had great difficulty in the available space (and working at night in the dark) disconnecting the clock - I couldn't figure out the latch on the connector. In the end I left this connector on.)
The bulbs for the heater are then accessible - their holders can be unclipped and the bulb then carefully removed. The awkward one is the one for the fug-stirrer/fresh-air slider, since it is between the two slider controls.
The bulbs are capless R286 dahsboard bulbs which are widely available (for example http://www.autobulbsdirect.co.uk/R286-Dash...ear.html). The bulb for the cigarette lighter is the same type.
LED versions of the same bulb are also available (the site in the link above has them).
To quote the old Haynes Manual classic, reassembly is the reversal of the dismantling procedure.
Post #48091 10th Dec 2010 12:08pm
wyvern
opss sorry POM,
I meant to get back to answer your last post ...! Whistle
it's like what he says above (cheers Blackwolf!) Thumbs Up
enjoy! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #48102 10th Dec 2010 1:02pm
