Home > Td5 > TD5 Fan control install?
Page 1 of 3 123>
BCdefender
Canada 1999 Defender 110 Td5 CSW Orkney Grey
Hi,
Just wondering if anyone has any experience replacing the fan control on a TD5. I snapped the lever on mine and have the new part coming tomorrow.
Any tips or trick I need to know about before diving in to fix it?
Thanks a lot.
Post #480411 8th Dec 2015 8:18pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Dead easy. If its fhe tempratue and divertor side just remove the cover by the drivers window (rhd) and undo the cable clmaps etc. If its the other side remove the 4 screws that hold the clocks in and remove.
Then undo the screws that hold the fan speed control to the panel and make a note of the three wires and disconnect and make not of the position of the cable and undo.
Refitting is just the reversal 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #480498 9th Dec 2015 12:31am
BCdefender
Hmm.
Just opened the fan controller.
Looks like it comes with a new cable. If I take off the cable not sure how secure it will be if I hook up the old one. I guess I'll look up in the repair manual, if I can find it, how to hook up the new cable...
Post #480504 9th Dec 2015 1:53am
BCdefender
See pic in my gallery...
Post #480505 9th Dec 2015 1:54am
BCdefender
I have disassembled without too much damage! Will now install on the truck...
Post #480506 9th Dec 2015 2:24am
BCdefender
Installed and working. 60 min 😜
Post #480510 9th Dec 2015 5:35am
Motoberg
I don't really like the big slider control for the 2 speed fan, looking at the wiring diagram, you should be able to change it for a 3 position rocker switch ( of suitable current carrying capacity ), the resistor to give the low speed looks like its in the fan unit, not the switch itself, has anyone done this ?
Post #480547 9th Dec 2015 8:41am
Motoberg
Post #480550 9th Dec 2015 8:50am
BCdefender
I agree. The slider is terrible. Amazing it can't just be done on a rotating switch...
Post #480679 9th Dec 2015 3:38pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Post #480698 9th Dec 2015 5:04pm
Motoberg
3 way switch ordered, I'm going for it !
Thumbs Up
Post #480767 9th Dec 2015 7:08pm
ibexman
epictrail wrote:
Look here
https://shop.landreiziger.nl/modificatie/m...uring.html
Any Translation
Post #480770 9th Dec 2015 7:10pm
fathaggis
what lead connects to what pin . i have one to fit and its all disconnected Shocked
Post #480774 9th Dec 2015 7:14pm
epictrail
Translation:
Ventilation and heating of the interior of a Land Rover Defender depends on the heater fan. This heater fan speed is adjustable by means of a position switch that can run softer fan via resistors.
This rule is also the source of a poor and inefficient working fan making ventilation, heating and demisting of the vehicle is inadequate. Only in the TD4 models from Land Rover is an adaptation came on the stove and fan unit, for all Defender models to TD4 we have devised an electronic control.
This electronic control replaces the existing switch and control resistors and sends the current fan motor directly. This direct control of the fan motor will be adjustable and in many cases have a higher air output. As a result demisting will function better and the interior heater to get a better return so that the vehicle can be quickly heated.
The application of this modification requires some skill and assembly tools, so this modification includes assembly can be purchased in our workshop in Dordrecht.
Post #480778 9th Dec 2015 7:25pm
dorsetsmith
black wire to red arrow green/yellow to green arrow
green / slate Grey to yellow arrow
Post #480785 9th Dec 2015 7:38pm
Page 1 of 3 123>
