Home > Puma (Tdci) > Odd echoing exhaust note |
Al_The_Pal Member Since: 09 Feb 2015 Location: Near the bottom on the right Posts: 146 |
Hi
6 month old 110 with 6k miles. Had an odd experience today, did a 3 mile trip in to town, parked for an hour. Started up and drove 300t yds out of the car park, suddenly the throttle picked up on its own for 2 to 3 seconds and the engine note changed (enough for the Mrs to notice) ... It's kind of echoey and viberberating.... Not a mechanical "something loose" rattle.. The engine pulls as normal, but there is an echoing note from the engine, throttle response seems.. Jerky and this took 3 miles to disappear.... But there still seems to be a gentle top end sounding Tappety noise now. If it was a 300tdi we'd say the timing belt was on the way out and the timing had drifted half a tooth Always run on Shell fuel, ultimate every third tank or so. http://www.defender2.net/forum/topic8061.html?highlight=knocked Have read this thread and I don't think the symptoms are the same Is it possible for an EGR to get stuck at this mileage? Seems like an exhaust note change with a bit of an extra whooshing with the echo? Not sure how else to describe it Al |
5th Dec 2015 9:06pm |
I thought about that, but engine was dead cold, temp gauge on the stop and had only been running for two mins... I was under the impression that it would only start a cycle if the engine was up to temp?
And I have noticed dpf before, this wasn't like that I don't think |
5th Dec 2015 9:51pm |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
It's broke. Sell it now before it does it again
5th Dec 2015 9:54pm |
Could you elaborate more on what more info you need
Unfortunately I'm not sure if I've supplied enough info or not Normally I find this place a useful source of friendly help Thanks for your help though |
7th Dec 2015 6:09pm |
