Home > Puma (Tdci) > 110 CSW back seats removal
rleslie
Scotland 2007 Defender 110 Puma 2.4 XS CSW Epsom Green
I'm looking to remove the 2 folding rear seats in my 110. I've read people using rivnuts to plug the holes. Is there any reason why I can't just use the bolts from the seats. That way I can re-fit them in future if I ever need them again? Or would the bolt get in the way, as I plan to fit mantec stowage cages.
As long as water does not get in.
cheers Richard
Post #469963 6th Nov 2015 8:40am
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
You can just use the bolts, with no problem. Although the you will need 2 substitutes, 1 for each side as there is a stud that is part of the seat that will come out.
Post #469964 6th Nov 2015 8:45am
RRUK
I did this a month or so again on my 90 CSW, it's an easy enough job.
Yes you can replace all the fixing nuts back in the holes they came from, I coated mine in copper grease too, so that when I/ the next owner need to put the seats back, they are not stuck, plus it adds some waterproofing.
As said, there are two holes you will need to bung up, I just used 2 bolts with washers, again, covered in copper grease and then all over the ends of the threads in the wheelarch to protect them. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #470001 6th Nov 2015 10:43am
treps
To help prepare for when the car hopefully eventually arrives, what size bolts is needed? Thanks
Post #470258 6th Nov 2015 11:50pm
Mjibex
I used M8 bolts (can be the shortest you can find) - I used dome/screwed headed bolts for a flatter profile. The hole is quit large so I used oversized washers also.
Mark.
Post #470827 8th Nov 2015 10:04pm
RRUK
Me too 2016 D4 HSE
Post #470901 9th Nov 2015 10:11am
YOLO110
Australia
Mee three! Very Happy YOLO... You Only Live Once...
Post #470908 9th Nov 2015 10:32am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I also used these highly specialised automotive-grade gaskets to keep the moisture out Very Happy
[/img]
Post #474052 18th Nov 2015 10:18pm
MJN110
United Kingdom 2016 Defender 90 Puma 2.2 Landmark LE Montalcino Red
Did mine yesterday used oversized steel washers and a rubber washer same size to make a good seal.
Easy on the torque when you make the bolt up all you will squeeze the rubber washer out.
Post #479118 4th Dec 2015 5:55pm
