Home > Td5 > Help, stranded
Motoberg
Help, stranded
Just getting a click when I turn the key, battery seems fine, lights aren't dimming like I'm pulling many amps.
Anything I can hit ?
Post #479107 4th Dec 2015 4:34pm
farmer giles
immobiliser?
try getting out of the vehicle; locking it; then unlock and try ignition again.
my tdci has played tricks on me like that
Post #479108 4th Dec 2015 4:40pm
g-mack
alway worth citing starter motor!! Laughing My 109 thread
my youtube channel
Post #479110 4th Dec 2015 4:43pm
Motoberg
Tried that, unfortunately not
Post #479111 4th Dec 2015 4:43pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Sounds like your starter solenoid has worn out contacts. Keep turning the key several times, sometimes you get lucky and it sparks and catches. Otherwise bump start it and don't turn it off. If you are on a small incline you can try forward or reverse bump start, you only need about five feet to do it. If it is the solenoid its a half hour job to repair and the kit is available very cheap. Good luck. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #479112 4th Dec 2015 4:44pm
dorsetsmith
Relay under driver seat Exclamation
if is starter motor see link below
http://www.aulro.com/afvb/projects-tutoria...r-diy.html
Post #479129 4th Dec 2015 5:24pm
mk1collector
If it clicks I'd say starter motor too, it should jump start. Ray
My build thread
Post #479195 4th Dec 2015 9:24pm
uncas
Broken earth lead gearbox to chassis. I had similar symptoms and changed my starter when it still wouldn't start we investigated further and eventually found that earh lead terminal end had broken at the gearbox .
Uncas
Post #479235 5th Dec 2015 1:47am
Motoberg
Thanks Chaps, I need to go back to work this morning to pick it up, I'll get a tow start to get it home and see what I can find.
Post #479280 5th Dec 2015 9:27am
Motoberg
special tap on the solenoid with a calibrated hammer did the trick !!
best think about a long term fix though !
Thanks all
Post #479326 5th Dec 2015 12:01pm
4RF RDS
The solenoid contacts! Bottom one is worn after 100,000km top is brand new.
1967 MGB GT
Post #479350 5th Dec 2015 1:45pm
mk1collector
Thanks all
Solenoid contact kits on eBay are only about £15/£20 and are really easy to fit Ray
My build thread
Post #479363 5th Dec 2015 2:01pm
dorsetsmith
dorsetsmith wrote:
Relay under driver seat Exclamation not this time
starter motor repair see link below
Post #479381 5th Dec 2015 3:46pm
miker
This is a very timely topic. Over the last few days mine has developed a habit of clicking when I turn the key, then only turning over a few seconds later. Likely to be the same problem?
Post #481655 12th Dec 2015 11:23pm
4RF RDS
Dat's da symptom dude... Didderdun quickly! Thumbs Up
Rolling with laughter 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #481659 12th Dec 2015 11:43pm
