Home > Puma (Tdci) > Main Relay and SJ1 |
Coolcamper55 Member Since: 22 Apr 2010 Location: Inverclyde Posts: 45 |
I am in the middle of trying to sort a problem and have need of some tech info
Main Relay what is the spec of the relay. I know it is fused on 30 amps but would a standard 30 amp relay be a suitable replacement? SJ1 this appears on the circuit wiring diagrams and is a common point for the connections to some of the items of interest in debugging only problem is I do not know where it is or what it is. I have trawled thro the connection document but unable to find a location, lots of referrals in the "connected to" lists but no idea where it is. Can anyone help, much appreciated Tommy 110 XS TDCi |
4th Dec 2015 4:20pm |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 496 |
The main relay is YWB500060
http://www.rimmerbros.co.uk/Item--i-YWB500060 Click image to enlarge It's not particularly expensive - £4.76 inc VAT I'm sure that this is a standard 40A 4-pin relay. The location of SJ1 is shown in the wiring diagram - Click image to enlarge The distance from each connector (or splice joint) to SJ1, is shown in mm, after the wire colour and gauge. . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
5th Dec 2015 5:14pm |
Superb, many thanks SJ1 must be in the box under the seat well hidden though.
I have a new 40 amp relay which I tried but it blew the fuse so beginning to think that its a wire that's been bared and is shorting probably the engine area. Tommy 110 XS TDCi |
5th Dec 2015 10:30pm |
Solder is not a problem, background is radio /electronics but must admit auto electrics is a whole different ball game Tommy
110 XS TDCi |
5th Dec 2015 11:42pm |
