Home > Maintenance & Modifications > Inverter in rear |
Ayrshirelandy Member Since: 28 Mar 2015 Location: Ayrshire Posts: 140 |
I am thinking of installing a high power inverter in the rear of my 110 Utility. I was wondering if anybody has done this and any tips. I want to run a fridge and some other things so thinking of 12V Modified Sinewave 1000W Inverter from Maplin. I would want to hard wire this as the use the accessory socket would not be wise.
I would appreciate any input or working diagram. Thanks 2015 Defender 110 XS Utility Santorini Black, sawtooth alloys, steps and so much more........... |
1st Dec 2015 10:42pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Hard wire it either from the battery terminal or the input side of the starter solenoid.
2nd Dec 2015 12:58am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20190 |
Direct from battery using a VSR I would say, possibly an isolator switch too.
2nd Dec 2015 1:21am |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Related question: I have seen various methods of providing protection on the 240v side of the inverter. Is it recommended to put in an RCB and also to earth the truck to real ground via some sort of earthing stake...? Or just leave the 240v floating..?
Cheers Simon Ps was going to make the same point about the 240/12v fridge... |
2nd Dec 2015 9:59am |
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 |
As Brendan says, wherever possible much better to get 12V kit rather than inverting
Can get 12V chargers for most things now including laptops etc. |
3rd Dec 2015 11:11pm |
