![]() | Home > Puma (Tdci) > Rear Diff Pinion Seal Part Number? |
jomara Member Since: 26 Oct 2009 Location: Lanarkshire Posts: 1790 ![]() ![]() ![]() |
Have a look at lrparts.ru, select "in English" from the menu bar, click the "enter microcat" link then select Defender 2007- from the side bar
![]() ![]() Click image to enlarge 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Fish13 Member Since: 17 May 2015 Location: Aberdeenshire Posts: 71 ![]() ![]() ![]() |
Many thanks jomara, it's a very useful site.
There's two rear axles shown in the microcat and depending on which one it's either: FTC4851G Or, FTC5258 Can someone put me out of my misery? Is the FTC5258 for the 90 and the FTC4851G for the 110? Cheers, Fish. |
Hi Fish
5258G is for a 90 (2pin diff) 4851g is for the 110 (4 pin diff) Hope this helps ![]() Cheers John 2014 110 2.2TDCi XS Station wagon 1971 Bowler Tomcat 88 4.2 V8 Auto 2022 110 D250 XS Edition - Gone 2024 110 D250 X-Dynamic HSE |
Brilliant, thanks jomara,
Next piece of info I had gleaned was that it's advisable to change the flange while you're at it, as if it's scoured or in any way marked, you'll be back with a leaking seal in no time. Has anyone got a recommendation or know of anyone that sells the 'kit' (Flange, seal, nut and bolt)? I'm not quite at 'genuine parts' prices, but also had bad experiences with the 'blue box' company too, so a middle of the road would be good! Cheers, Fish. |
milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873 ![]() ![]() |
Is the OEM Corteco? I used their seals from Paddocks on my Series 2 axle rebuilds. I wouldn't use a blue box part for this.
Many thanks milesr3,
I've gone for the Corteco seals, no blue box! Cheers, Fish. |
