Home > Td5 > Td5 oil |
Justtellme Member Since: 23 Nov 2015 Location: Ottawa Posts: 310 |
Apologies.....likely this topic has been beat to death here, but......Cheapest deisel oil I can find locally here is mobile one "turbo diesel truck" 5w30. Looking on line it has a ACEA rating of E7.
The handbook ( in German, so I'm guessing here) is ACEA A1 /B1....which appears to be a spec from the early 2000s?? Will E7 meet the requirement? Not really up to speed with these euro oil specs, though I did find a ref to E7 being a commercial specification. Thanks Patrick |
30th Nov 2015 10:59pm |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 |
Cheapest oil is whatever you find in the supermarket/ebay,simples. Pov.spec,ftw. 2006, 110,TD5.
1st Dec 2015 4:35pm |
Ok thanks
Patrick |
1st Dec 2015 4:51pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
E7 will be fine, It's a better oil than A/B/C Rating designed for hard use and longer oil change intervals Guns and Landrovers .... anything else is irrelevant.
1st Dec 2015 8:45pm |
Super...thanks I'll pick some up.
I wanted to do an oil change at the same time I do the oil pump bolt rectification. The local LR dealer said my 2003 TD5 was outside the window for the oil pump bolt horror show, but some witnesses in Australia report some TD5s with no lock tight on the bolts as late as 2004. They also mentioned that the problem/recall for this bolt was only applicable to the Disco 2. Sounds strange unless the TD5 engines were built on two separate assembly lines for the Disco and the Defender?? Patrick |
2nd Dec 2015 12:49pm |
