![]() | Home > Maintenance & Modifications > Puma clock Light Bulb |
Macpaul Member Since: 25 Mar 2013 Location: SW Surrey Posts: 439 ![]() ![]() ![]() |
If it's any help, I have a broken bulb (not) illuminating the rhs heater control on my 2013 USW.
After some rummaging, the LR parts dept sold me part RTC 3635 at £1.43 which looks right. The bloke said it did most of the dash lights. I'm embarrassed to say the problem I've got is that I can't get the old bulb out of the holder. It won't pull, push or twist and I don't want to mash it with pliers in case I have to get the dealer to do it under warranty and make it more difficult. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 ![]() ![]() ![]() |
http://www.defender2.net/forum/topic16996.html ![]() Click image to enlarge Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
That's the one and I see most places sell them for about 25 pence.
And I went and and tried again after my post and managed to change the bu99er. 2003 Td5 110 Hardtop Now a 2013 110 USW too. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17602 ![]() ![]() ![]() |
So did anyone establish for sure what the clock bulb actually is?
Is it STC1205 same as the hazard switch? Mine has become very dim and needs changing ![]() |
Rickydodah Member Since: 14 Jul 2014 Location: East Sussex Posts: 1091 ![]() |
http://www.ebay.co.uk/itm/361324831214?_tr...EBIDX%3AIT
Got this from a previous post, bought one and works well ![]() |
Thanks
![]() That looks to be the same as STC1878 (green) which means that STC1205 (clear) or STC1877 (orange) should also fit I think. That Ebay link is massively expensive though at £4.99 - these bulbs are generally about £1.50 each from LR ![]() |
The Puma clock bulb appears to be the same shape and size as a Disco 2 clock bulb, YAW000020 (formerly YAW100030), but the Disco is clear and the Puma has a green sleeve over the bulb.
It is the same as the Ebay link above (Boltonbits), which is actually the only source of green ones I have sofar found (clear ones are available from many sources). The three part numbers listed in my post above are the smaller bulbs of the type to fit the hazard switch and are different to the clock. |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Another happy shopper here:
http://www.ebay.com/itm/291703553888?_trks...EBIDX%3AIT If the link dies it was from seller 'sellyservice' - search out '12V 2W RU509TMGR' Same seller also has the oil I used in my 2.4 Puma gearbox and transfer box: 'CASTROL Syntrans Multi Vehicle 75W-90 Manual Transmission Fluid' ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20613 ![]() ![]() |
Hate to quote another post again, but on this one occasion I will. It's funny you post that pic, that was mine which I took and fitted a few years ago. I was just going to mention is it the sameas the rest of the dash bulbs? The P/N for the bulb above in the photo I had replaces the bulbs in and around the centre dash. I'd be inclined to think it might be but could be wrong, I The are a push fit and also sods to remove. |
