![]() | Home > Maintenance & Modifications > Linking batteries |
that sounds perfectly sensible.
Have you deliberately chosen to use an ignition feed rather than a VSR? If you run the second battery down then turn the ignition on, your starter battery will be trying to charge the second one which isn't very helpful if you're also trying to start the engine. The other thing is have you looked at the specs for your current relay? It might be that it can stand a few hundred amps for the few seconds you need to start. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5852 ![]() ![]() ![]() |
The reason being for not having a VSR is simple....I didn't have one!
It is something I am thinking of adding instead of the ignition feed activated relay. The relay I am not 100% of its rating, it could be 80amp with 120amp peak.... ? TBH, a winch relay is probably better for the job than a relay ? 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
There's also the VSR with built-in Start Assist function, e.g. the Cyrix has this. You could combine this with a switch in the negative feed of the Cyric, then you have exactly the setup you want:
Auto (start assist switch off, negative feed on) Linked (start assist switch on, negative feed on) Off (start assist switch off, negative feed off) With a bit of creativity it might be possible to combine the switch functins in one switch. ![]() Click image to enlarge Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
Normally a winch soleniod is not to be powered hours a time. Surely the old ones didn't like that.
![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
The idea came from seeing this
http://www.ebay.co.uk/itm/T-MAX-12V-Digita...xyXzxTGYXt which has a 250amp continuous rated solenoid. 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
