Home > Td5 > Viscous fan |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2651 |
You will find if you keep turning it it will free up a bit if working properly. The fluid settles a bit so it will be stiff from rest.
Best test is to start the engine from cold, let it idle for a few seconds, and then try to stop the blades with a rolled up newspaper. Should be able to stop it fairly easily. Once hot it should turn the newspaper into confetti. |
29th Nov 2015 9:09pm |
Alex1976 Member Since: 23 Jan 2013 Location: Buckingham Posts: 596 |
It will be quite stiff for the first few turns but then should loosen up. It still won't spin really easily though, so unless it is really hard to turn then it sounds ok.
29th Nov 2015 9:11pm |
