Home > Puma (Tdci) > Diff lock
Mr.Boots
Ireland
Diff lock
Got a bit stuck in the snow today so after a bit of going foreword and backwords trying to free it i decided to try Diff lock (first time) light came on the dash but it didnt seem to help the situation at all, front wheel still spinning and the rear doing nothing....is it shaged?
Ive never used it before so i thought i might be doing something wrong.
Post #47373 4th Dec 2010 5:08am
110SEB
It's best to use before you get stuck. It fuses the front wheels together and the rear wheels together, but not the front and back together, if you see what I mean Neutral If you know you're going to be driving on something that you know will offer very little traction then you're better off with difflock on, but remove it as soon as you're on solid ground as the two pairs of wheels will not necessarily spin at the same rate (when turning for example) and may cause damage.
Difflock may not always switch off immediately, so try reverse a little and then forward to release it. In reality in icy snow try difflock and low range 2nd and your Defender should just march through. Things are always much harder once you're stuck.
Hope this helps but I know there'll be much more advice on it's way...
Thumbs Up
Post #47380 4th Dec 2010 9:34am
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
110SEB wrote:
It's best to use before you get stuck. It fuses the front wheels together and the rear wheels together, but not the front and back together, if you see what I mean....
Eh? CDL fuses front and rear prop shaft. Front and rear DIFFs get the same torque. However, left and right front are still independent and left and right rear are still independent which is why you can end up cross-axle'd and going nowhere (which traction control tries to remedy).
Seb - I don't for 1 minute question whether you know how CDL works but I think your explanation was a bit confusing Wink One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #47652 6th Dec 2010 11:53pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
From your experience guys, is front diff lock enough? Or shall I go for both - front and rear.
I am preparing the vehicle for overland expedition - sand and mud expected. Janusz
www.yahodeville.com
Post #47674 7th Dec 2010 10:10am
alantd
You should be OK with just the centre lock (I assume your 2007 PUMA has traction control) but if you want to spec it up, generally a rear locker is the way to do it. A front locker will seriously hinder your ability to steer.
The main thing to do is to ensure your half shafts are up to it. If you're feeling like belt and braces, upgrade the front diff as well to cope with the extra torque you'll be putting through it. One that started out as a 2.4 TDCi 110 XS
Post #47676 7th Dec 2010 10:18am
Naks
Re: Diff lock
if your CDL is engaged, the front and back wheels should be rotating at the same speed.
Post #47699 7th Dec 2010 1:23pm
DefenderOfTheEarth
Diff lock should make a BIG difference to grip.
Got stuck in a field (icy "ramp" down to it) two weeks ago - no way it would get out without difflock (unless I took a big run up - which wasn't possible). With difflock I got out the 2nd time. Defender 110XS SW gone... now VW California 180 4 Motion.
Post #47700 7th Dec 2010 1:28pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
In theory, with out the centre diff locked all the engine power can go to just 1 wheel (1 wheel drive), with it locked then the power has to go to at least 2 wheels (2 wheel drive).
If you then put a rear locker in the rear diff you then get full power to at least 3 wheels. Its only when you lock all 3 diffs in the transmission that you get get true 4 wheel drive.
This is all in theory, in the real world it very rarely works like that and unless your are cross axled or on pure flat ice up a hill then forward momentum is normally not lost, as long as you use the centre diff lock to provide 50% power to the front and 50% power to the rear.
Pete.
Post #47702 7th Dec 2010 1:54pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Yes having just a CDL on means you can put all the power through 1 front and 1 rear wheel - both of which will spin nicely. There's plenty of threads on here with descriptions of operation
Just to support what others have said I spent much of the weekend on sheet ice, often on hills up to 1 in 4 here in Dartmoor using just the CDL. Had the front and rear ARB lockers primed ready to go but with a bit momentum, a modicom of slip I only had to use the rear locker once.
BFG 285/75 MT's did well considering the main problem was ice not snow
Post #47770 7th Dec 2010 10:20pm
