Home > Td5 > Changing power steering pump
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
Job for Saturday is to change TD5 power steering pump Sad
Any advice on this so I don't mess up?
Have got dexron2 as fluid replacement!
Post #476157 25th Nov 2015 8:20pm
grumpy old git
There was a feature in last months' Land Rover Owner I think with a step by step. My old Td5 had ATF in, no problems in around 80K miles.
Post #476371 26th Nov 2015 2:15pm
Tommo
Thing is I have about 7 litres of ATF left (used it for tractor hydraulic fluid) so will use this to keep costs down.
Haynes manual advises putting axle stands on front but speaking to independent he said no need!!
Any way have ordered steering pump from ACS who recondition old pumps and sell them for £89 with proviso you give them your old pump. Has 18 month unlimited mileage warranty with it Shocked
Looking forward to doing it. [/list]
Post #476467 26th Nov 2015 8:42pm
JWL
It's got to be 18 months since I did mine, no major drama apart from make a note on how the belt runs, which side of the pulleys etc. It gets a little embarrasing to be struggling to put the belt back on and it won't quite fit even prompting you to change the pulley on the pump just in case the second hand one was a different size. Quick check of the Haynes book of Lies and all just fell into place Whistle
Post #476490 26th Nov 2015 9:09pm
Martin 01
Tommo, do you have any details for ACS ?
My steering pump is leaking, don't know if it's just a replaceable seal or not.
Post #476735 27th Nov 2015 5:56pm
Tommo
Hi Martin
phone them on 01827 259699.
They operate an exchange system which is why they are cheap, you have to send them your old pump and this then activates the 18 month warranty.
cheers
Tommo
Post #476750 27th Nov 2015 6:32pm
Martin 01
Cheers Tommo I'll give them a call. Thumbs Up
Post #476846 27th Nov 2015 10:22pm
Tommo
Well pump changed!
Steering fluid is rank...what is the best way to drain the whole lot and replace??
Post #477177 28th Nov 2015 9:37pm
grumpy old git
When I changed the steering box on my D2 I siphoned as much as I could out of the reservoir then attached a brake bleed hose to the bleed nipple and left it to drain until it stopped. It's nigh on impossible to get it all out in one go so refilled and repeated, should have got the majority of the old out.
Post #477224 29th Nov 2015 1:27am
Tommo
A cautionary tale
Although I successfully fitted the pump I could not get it to pressure up Sad
Took all day Saturday and Sunday and took a day off on Monday to try to sort...turned out I had not put on the rubber o ring on the connection to the pump. Once this was done it was fine. Checked the Haynes manual and also the LR mag that featured changing pump and there was no mention in them about this tiny little rubber ring that caused all the problems.
anyway now all good.
Post #478102 1st Dec 2015 8:38pm
Boyd
France 2003 Defender 110 Td5 SW Zambezi Silver
Sorry to bring up an old thread but.....
any idea which LRO magazine had the feature in it? Whistle
I am mid change at the moment and there is obviously a bolt i can't see that i'm missing as the ruddy thing won't move! Big Cry 2003 Zambezi Silver TD5 110 XS SW overland prepped....
2004 Santorini Black TD5 110 XS SW left hooker for sale!
2004 Alpine White TD5 110 left hooker (work in progress)
Post #742939 29th Nov 2018 12:43pm
Tommo
Hi Boyd
from memory there are 3 bolts to remove once the pulley is removed.
Have a look at the landrover defender workshop manual on line if stuck.
good luck
Tommo
Post #743030 29th Nov 2018 9:15pm
Boyd
All done thanks, saw it on the workshop manual blown up image.... hadn’t realised the lower two bolts both went through the front bracket and into the main casting. Thumbs Up 2003 Zambezi Silver TD5 110 XS SW overland prepped....
Post #743044 29th Nov 2018 10:04pm
