Home > Maintenance & Modifications > run 24 volt item from 12 volt system ... |
wyvern Member Since: 13 Dec 2009 Location: Cornwall Posts: 2117 |
Hi all,
Ive been offered a 24 volt Eberspacher cab heater for my wagon at a good price, but only have a 12 volt system … So can I step up my system to give me 24 volts from a 12 volt system? If so how? Is it going to be easy or will it be too expensive to be worth it? Hoping for a warm wagon at night when camping!! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html Elgar -TDCI(Puma) 110XS Dormobile - now sold Devon & Cornwall 4x4 Response - DC126 |
6th Dec 2010 9:53am |
Use a transformer (switching) 12V to 24V...............
http://www.aaroncake.net/circuits/12VDC_To...ircuit.asp or http://www.webalice.it/crapellavittorio/electronic/da12a24v.htm or http://www.webalice.it/crapellavittorio/electronic/switc12v.htm Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
6th Dec 2010 3:09pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8582 |
It is possible to get a 12 v/24v converter. Just google it
You would have to check the current draw on your potential heater. Am guessing the higher the current draw the more expensive the converter will become Will it be worth it? Hmm that is your call HTH Brendan |
6th Dec 2010 5:10pm |
