Home > Technical > Viscous fan question |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5663 |
Don't sound correct to me.
I thought it should lock up the hotter it got?????????? Is it fully locked? Mine can be turned by hand and it is -2 here at the mo. May be worth removing it and see what happens to the MPG. Can't think one is required at these temps. Andy |
6th Dec 2010 1:09pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Yes andy it's fully locked as far as I can tell. It's sucking through the grill like Gillian Taylforth in a lay-by
6th Dec 2010 1:22pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
it was on a slip road Justin 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
6th Dec 2010 1:34pm |
Or even a trunk route |
6th Dec 2010 1:40pm |
If any of you guys would not mind checking in the morning to see if your does it I would be grateful. I can then ring the dealers and when they say "they all do that sir" I know what to say.
I just want to be sure it is not common to all Pumas Thanks Boy |
6th Dec 2010 4:32pm |
what about Gillian Taylforth Justin ? 2.4 90 XS 1968 1/32 scale Britains 109 Pick up. |
6th Dec 2010 4:51pm |
You remember her, eastenders star caught giving her boyfriend a BJ on the side of the A14 and went to court and lost. I sure there is a lesson in there somewhere |
6th Dec 2010 5:17pm |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 |
mine does for a couple of minutes - all my vehicles in the past have also stayed on when started
6th Dec 2010 5:28pm |
Thanks It just worried me a bit as non of the TDi's I've Had/have do it. Cheers |
6th Dec 2010 5:32pm |
The classic tdi's and v8's did.
anyone removed it from their puma? thinking of doing it, as it runs all the time when doing over 70 |
6th Dec 2010 5:36pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
My '07 Puma's fan was quiet on first startup in the mornings but the fan on my new one roars for a minute or two. Steve.
7th Dec 2010 12:10pm |
Mine is more or less staying on all the time now so I have booked it into the dealers. I hope it does not unlock when I take it in. Knowing my luck it probably will.
If they don't change it then think I may just buy one and change it myself, anyone know how much they are? |
4th Jan 2011 1:12pm |
