![]() | Home > Puma (Tdci) > RedeX |
Caterham Member Since: 06 Nov 2008 Location: Birmingham Posts: 6318 ![]() ![]() ![]() |
just bought some.
in the good old days of carbs I used to add this stuff to the petrol and it didn't seem to do any harm - not sure it did any good either ? ! anyway I'm hoping to keep the def long term and if this diesel additive is going to do some good I don't mind spending the extra £1 on a tank ful - so long as its not doing any harm ![]() any thoughts..... |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
Just change the engine oil every 6k.
Most additives do more harm than good ![]() Discovery 3 HSE BMW 330i Coupe |
Have a look at this.
http://www.carbibles.com/additives.html Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
There's more here,
http://www.skepdic.com/slick50.html Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
erm
I'm talking fuel additive not engine oil. |
They all end up in that lump of metal under the bonnet
put millers diesel additive in it every tank and change your oil every 6k
http://forums.moneysavingexpert.com/showpo...ostcount=9 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
Defendit Member Since: 31 Oct 2010 Location: Down Under Posts: 26 ![]() ![]() ![]() |
Yes, use 2 stroke instead. ![]() http://www.freel2.com/forum/topic878.html? will give you the basics, but read it from the start and then do some other searching of the net. ![]() |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
Re. oil change - What about the dealers recommended interval of 12K miles?
Not that I'm doubting anyones wisdom - I think it makes more sense at 6K... |
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
I use "Forte" diesel, engine and gearbox additives.. i fill fresh diesel filter with 50% of Forte treatment and remainder to tank the car is instantly smoother. I think only garages can buy it but it pops up on Thievebay now and again. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
+1 Use 2-stroke in the landy and in the Audi A3 - both run much more smoothly with than without ![]() |
I agree about the Forte, it does make it run smoother and helps a little with mpg, but have you seen the price!!
![]() ![]() ![]() ![]() Boy |
I forgot to add that every 5000km or so I add a bottle of diesel injector cleaner in both the Audi & the landy just to clear the cobwebs
