Home > Off Topic > proud to present the Mi.G01
dgardel
Italy
Totally designed by me (also the frame with 80% of modification vs the original Bremach)
Mi.G01 link on "army recognition"
Please, note the "SNOW COVER"
Mi.G01 meets and exceeds the NATO STANAG 4569 LEVEL 2 Standard.
Gearbox and transferbox
Two type of gearboxes are available:
 ZF Manual 6 speed with overdrive
 Allison Automatic gearbox with torque converter.
Several types of PTO are available up to 55 kW:
 From the gearbox
 From the transferbox
Axles
Rigid axles equipped with leaf springs and telescopic shock double action absorbers for maximum stability even in extreme situations
Ballistic Data (STANAG 4569 - LEVEL 2):
 Ballistic protection level of the bottom part of the vehicle: ARMOX Advanced mineproof
 Ballistic protection level of the vehicle sides: ARMOX Advanced
 Ballistic protection level of the vehicle roof: ARMOX Advanced
 Ballistic protection level of the vehicle windows (all): STANAG 4569 - EP55 - LEVEL 2
Length: 5840 mm approx.
Height: 2450 mm (with no load, standard equipment)
Width: 1970 mm approx. (exc. mirrors)
Engine: Twin-Turbo diesel engine F1C Iveco, with 190 PS
500 Nm torque output
Gradient Climbing: 80% - 95% (version dependent)
Water fording: 700 mm (1500 mm with optional external snorkel)
Minimum ground clearance: 295 mm
Departure angle (B): 35° - 40° (version dependent)
Approach angle (A): 46° without winch
Ramp break-over (C): 142°
Standard Wheels type: 255/100-R16 OFF ROAD M+S
Front axle max load:. 3000 kg
Rear axle max load: 4500 kg
Total weight: SW 4980 kg (versions and fittings dependent)
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #475596 23rd Nov 2015 8:38pm
T1G UP
Cool
Post #475634 23rd Nov 2015 9:44pm
LiftedDisco
Holy Moly... that's, er, how shall I put this, substantial...
Can you get the wading level improved... the air intake must be kinda low for 700mm as the new full fat RR achieves 900mm!
Looking forward to seeing a squad in full riot gear piling out of that and then hanging their belt loops on the door catches - speak to Simon about his version...
Good luck with it!
Post #475638 23rd Nov 2015 9:55pm
dgardel
Italy
Yes but it is a problem due to the necessary overlap for protect the door gasket zone from the bullet Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #475642 23rd Nov 2015 10:08pm
Pilgrimmick
What environment is it designed to operate in? The cooling for crew and engine seems to be limited. Could more use be made of horizontal surfaces for cooling, these are far less vunerable to hostile fire?
Post #475647 23rd Nov 2015 10:36pm
dgardel
Italy
Grill is not definitive (I don't like) and it was "attached" at two o clock in the morning just before the truck was loaded on the trailer.
The definitive one will be like this one.
The bullet barrier is in front of the radiator made by armored steel like we use on our armored car builded by us (alternating bands) and well tested.
and, in the "hot climate" version, the vehicle is equipped with two air con systems (plus an uprated thermal insulation) Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #475659 24th Nov 2015 12:20am
